Borrowed from Jay95's Leather Handbrake Boot installation instructions.....
What we need to do is take the centre console (the part between the two front seats)out of the car.
With the plastic surround that goes around the gearstick still off, undo the two screws that were under the plastic surround that you just took off.
Then open up the centre console bit and undo the two screws inside the compartment. If your car has duel airbags, then these two screws will be on the outside of the console, on either side of it. You can get to them if you move your seats all the way forward and tilt them forward too.
Once the screws are out, unbutton the to studs that are on the factory handbrake boot, then the whole centre console bit can be lifted up and forward to get it out of the car. Just be careful not to scratch your stereo with the console when you take it out.
Once the console is out of the car, turn it upside down and with the help of a small flat headed screwdriver, gently prise the handbrake boot out of the console.
The factory handbrake boot has a wire frame sewn around the base of it.
Once it's out of the console, you'll need to cut the wire frame out of the factory boot, and sew it into the base of the new boot. Just remember the way the frame is sitting in the factory boot. I'm pretty sure the high side of the wire frame goes to the drivers side.
Once the wire frame is sewn in, pop it back into the centre console and re-install the centre console and the plastic surround around the gearstick.
Whala - all done.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
