Well my drift car project is finally nearing a finish.
I am wanting to do the 2 tome with black above the window line and white all below
It does look quite aggressive with the kit being black though.
So we might have the black under the top of the side skirt line all the way around.
Colour change skills will be much appreciated.
;) Aaron
https://www.sau.com.au/forums/topic/162291-colour-change/
We taking bets on the time it takes to get defected?
The Slide plates are going on it.
To make it fair it will not be for reasons other then random pull over.
My bet is 2 weeks.
I also bet it will happen when i am in Sydney.
And yes Silvia came out with RB's *whistles
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3014263
No ?
Cry me a black and white river emo kid and paint the car lol
It will be painted this weekend coming black above the window lines and white below.
It will go well with the stickers that are the same that are being used on other sponsored cars.
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3035986
Ok now the bet is for how long it takes me to get James' keys when im in Sydney and to get his car on the hoon list :w00t:
My bet is 20 minutes and 5 seconds
key??? whats is this key you speak of?
you mean to say that I'm NOT allowed to drive other people's car by the exposed wire method??.....DAYUM!!!
:):D
https://www.sau.com.au/forums/topic/162291-colour-change/#findComment-3037659
