Cost will be $50 members and $55 non members.
There will be prizes for each category of:
Stock Turbo R32 GTST
Aftermarket Turbo R32 GTST
Stock Turbo R32 GTR
Aftermarket Turbo R32 GTR
Stock Turbo R33 GTST
Aftermarket Turbo R33 GTST
Stock Turbo R33 GTR
Aftermarket Turbo R33 GTR
Stock Turbo R34 GTT
Aftermarket Turbo R34 GTT
Stock Turbo R34 GTR
Aftermarket Turbo R34 GTR
but only if you all behave yourselves. The prizes are small and not worth fighting over or cheating for.
Dyno is a rear wheel drive dyno but GTR's will have their fuse pulled or drive shafts removed free of charge.
9am til 4pm or later if there are still cars to go on. I will be there a bit before but first car goes on at 9am.
This looks like being a big one guys. I will be taking money and names on the day so that everyone goes on the dyno in order of arrival. Bring your membership cards club members. We will have membership forms available on the day for those who want to join.
UAS is now located at Unit 1, 20 Tucks Road, Seven Hills. You go to the end of the M2, turn left, 1st right, 3rd left then it's down the end on the right. They have a great new dyno room installed which is nice and quiet compared to the old one and has good ventilation.
Post your interest.
DON'T FORGET, IT'S ON THE 19TH OF MAY
https://www.sau.com.au/forums/topic/162320-sau-nsw-official-dyno-day-2007/
  • Replies 368
sounds good, will certainly come by.
John's new workshop is very nice. Its well lit and much nicer than the old shop, its all in the one unit as well lol There is plenty of parking which is a huge bonus :blink::)
is there a non Skyline category or do we count as a GTR :happy: :happy:
Edited by ido09s
    • Thanks Duncan! Yeah it's street use for me only. Maybe occasional track day. Any difference in noise when running with the two pumps? I would expect the lift pump to be more quiet than the main pump so hopefully not? And yes, unfortunately quite a big price difference to the simple hanger setup. Though I'm usually willing to trade money for better reliability and future-proofing. Buy once, cry once and all that. I'd be very happy to never have to deal with fuel pump / wiring issues again
    • The old manifold was quite under the GTR strut brace.  The new manifold is quite [unknown] the GTR strut brace. The GTR strut brace was needed to clear the bonnet vents. The Old strut brace will almost certainly clear the new manifold, but not the bonnet vents. The old strut brace will almost certainly clear the new manifold, and the new bonnet without vents. But I am hoping the GTR strut brace clears the new manifold :p
    • On the bright side, at least you knew that it happened and remedied before anything happened. A friend of mine just took his Fiat 124 to a shop for an oil change and they didn't tighten the oil filter housing properly. 4.5 quarts spewed out and even after refilling + tightening the cap the engine has a tick now.
    • So, more pain. The FAST manifold is a little larger than the stocker. This is problematic because there really wasn't much clearance to begin with, so going from 'barely enough' well into 'no' is sad based on the external dimensions of the thing, even though where it bolts to the head is the same. Result is the fuel rails sit a good 25mm higher, and this is a bit of an issue with the wiring that runs behind the motor, and the fuel lines, and everything else. When pushing the manifold on, it required a huge amount of force to crush wiring looms to fit it, sensors like the MAP sensor are about 1mm from the firewall, and the FPR just has to bend ABS lines to be forced into place. After some brainstorming and some sad drinking, the loom for some reason ran from the grommet behind the ABS sensor, then to the driver side head, then back to the passenger side head. So all of this was pulled back and stripped, a few wires cut and rejoined, so that the 'branch' was now on the passenger side's head as below: Before you basically couldn't see anything behind the driver head. This is much improved! The MAP sensor is now pointing up (instead of at the firewall) Brackets have been made up for the rail. The rails are for a LS1, the manifold is designed around a LS2 as it's base. Which of course has slightly different bracketry and water pump clearance, hence the mods people need to do. Should be hopefully mounted tonight. I spent money on a new FPR that is slightly more compact than my Turbosmart FPR1200. The gauge has also been moved to the rail. There's also apparently an ORB to AN Union instead of the adapter, because the ~25mm of the current adapter is going to make the difference. Provided this all goes together and arrives today, it'll be the totally not stressful attempt to start it.
