Hey Joeyz, they won't necesarily tinker with the car. There's generally no time.
Unless it's Ben that's running the cars up, and your name is Mona, and you say, "I don't care what it gets just make sure I beat wilch!"
Then you make close to 500rwkW with a tiny turbo.
lol
^^ That was quite amusing last time when mona ran VERY HIGH numbers.. all in the turbo!!..
Should be a good day, looking forward to it..
LMAO!!!!! that was funny as hell!!! it made everyone do the double take!!! :D bens a top bloke! didn't think he'd go for the idea!! awesome stuff :)
  • Replies 368
2rismo i thought that a smaller wheel would improve the power output. dont think it will be worth it though. What kind of impact does fuel have on output? has anyone tried running different types of fuel?
also can u use nos on a dyno? that would be crazy....
umm was I the only person who spotted lingeringsoul was being damn funny.
Dyno days always seem to bring out everyone's serious/competitive side :D
I thought it was funny.. lol..
Sorry all I have Some bad news, I have to head up the coast on friday night and I wont be back for the dyno day.
Sorry, but at least someone else will get a shot at the STD R33 gtst award I was chasing.
:dry:
Does it matter what time you turn up to Dyno day
I wont be there till after lunch and want to put my car on.....
.....couldnt see why that would be a problem !
- ive never been to a dyno day - i think im going to to go & have a look & say hi to everyone - should be fun im sure !! :)
yeah true :(
Awesome would be nice to see you again....
Malcolmmmmm!
Long time no see! You should come out more with everyone! :(
    • Very decent bit of kit. Definitely black it out I reckon.
    • Because people who want that are buying euros. The people with the money to buy the aftermarket heads and blocks aren’t interested in efficiency or making -7 power, they’re making well over 1,000hp and pretty much only drive them at full throttle  best way to way make money is know your customer base and what they want and don’t spend money making things they don’t want.
    • It's not, but it does feel like a bit of a missed opportunity regardless. For example, what if the cylinder head was redesigned to fit a GDI fuel system? It's worth like two full points of compression ratio when looking at modern GDI turbo vs PFI turbo. I'm pretty reliably surprised at how much less turbo it takes to make similar power out of a modern engine vs something like an RB26. Something with roughly the same dimensions as a -7 on an S55 is making absolutely silly power numbers compared to an RB26. I know there's a ton of power loss from things like high tension rings, high viscosity oil, clutch fan, AWD standby loss, etc but it's something like 700 whp in an F80 M3 vs 400 whp in an R33 GTR. The stock TF035HL4W turbos in an F80 M3 are really rather dinky little things and that's enough to get 400 whp at 18 psi. This just seems unwise no? I thought the general approach is if you aren't knock limited the MFB50 should be held constant through the RPM range. So more timing with RPM, but less timing with more cylinder filling. A VE-based table should accordingly inverse the VE curve of the engine.
    • I've seen tunes from big name workshops with cars making in excess of 700kW and one thing that stood out to me, is that noone is bothering with torque management. Everyone is throwing in as much timing as the motor can take for a pull. Sure that yields pretty numbers on a dyno, but it's not keeping these motors together for more than a few squirts down the straight without blowing coolant or head gaskets. If tuners, paid a bit more attention and took timing out in the mid range, managed boost a bit better, you'll probably see less motors grenading. Not to name names, or anything like that, but I've seen a tune, from a pretty wild GT-R from a big name tuner and I was but perplexed on the amount of timing jammed into it. You would have expected a quite a bit less timing at peak torque versus near the limiter, but there was literally 3 degrees of difference. Sure you want to make as much as possible throughout the RPM range, but why? At the expense of blowing motors? Anyhow I think we've gone off topic enough once again lol.
    • Because that’s not what any of them are building these heads or blocks for. It’s to hold over over 1000hp at the wheels without breaking and none of that stuff is required to make power
