Howdy people,
Posting up for a mate.......he can get his hands on some 20 Injectors cheap which are side feed like RB25's and we are wondering if anyone has done this mod before....success / what needs to be done etc....
The standard 20B injectors are 550cc, thats all i know im unsure if they will fit in rail etc?
Any info would be handy. :rofl:
- Luke
https://www.sau.com.au/forums/topic/162358-rx7-20b-injectors-for-rb25det/
Howdy people,
Any info would be handy. :happy:
- Luke
From memory (it's been a while since I had a set) the 20B injectors are the same as 1JZ & 2JZ, so they need adaptor rings, same as aftermarket SARD injectors. You can buy them separately anyway, so if the 20B injectorrs are cheap enough, grab them. Be careful though, I think they have 3 injectors at around 370 cc's and 3 at 550 cc's. Not all six flow the same.
:P cheers :huh:
As sk said, they are pretty much the same as sards.
You need the collars, and some standard denso type plugs and shave a bit off some of the plastic down at the bottom of the injector.
They work in mine.
  • 2 years later...
:P cheers :(
Anyone know exactly what collars are needed to fit the 13B side feed into the 25 rail?
Does it have to be sard or are there any other options?
Also i see sard has two different sized collars... one for the the 550 and one for the 850.
Thanks.
If you do a search you'll find lots of info on RX7 Turbo injectors .
From what I read it gets a bit confusing because the colour and even part numbers can be similar /same , it seems to depend on the model year of the donor engine .
I think the only hard and fast rule - with the conventional looking rectangular connector type , is that the locating tag on top of the fitting is offset to the right with high impedance injectors and center with low impedance peak and hold type injectors .
People say you simply file that tag off the high impedance injector and fit readily available std rectangular plugs .
Cheers A .
Ok guys after doing some research it seems like the Subaru STI side feed yellow top injectors can work on the 25det
Alot of Sr20 guys are doing the swap and says it fits as oem in the rail, are high imp,and just the connectors are different.
The problem is a little confusion over the USDM which claims their own is 550cc or thereabouts and the JDM spec which is 440cc
If this is true i can't believe there is no info on SAU to support this...... yes i've searched!!!
Anyone have any further info on this????
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
