I have just finished putting a set of r33 turbo brakes onto an r32 gts.
The brakes work very well but the pedal is a bit soft and has no feel to it. What i need to know is do i need a master cyliner off of an r33 as well to fix the problem, If the problem is caused by a mis match of master cylinder to callipers. Has anyone else done this if so, how well do your brakes work?.
https://www.sau.com.au/forums/topic/162370-r32-brake-master-cylinders/
What you need do is compare the piston area of the calipers of the new set up with that of the old. If it is much larger you will get a longer pedal travel, but not necessarilly a spongy pedal. The two are different things. Sponginess is usually caused by air in the system, so have the brakes been bled properly?
But yes a larger bore on the master cylinder will give you a shorter, harder pedal & arguably one with more feel.
