I am looking for things that i can buy for my car (r30 skyline hatchback), though i need to find cheap things.
I am trying to make it look better as i am already making it sound better....just some helpful tips on what could make
my hunk of junk look better then it already does.
cheers guys
DKr30
some of those spinning hubcaps are always a winner in my book
nice^^^^^^^
if you are just after looks get some tuff oldschool rims. no chrome.
or wack a rb20 and big front mount cooler. that will look tuff
cheers guys
DKr30
Firstly, NEVER NEVER refer to anR30 as a "hunk of junk". Go wash your mouth out with brake fluid, then come back with a little more respect for an offspring of Factory 5. We might then offer you some assistance. :laugh::) :) :nuke: :nuke:
im with 66yo!
Its not junk until its crushed into a 1m cube...
but dude get a picture up, we might be able to sort something out...
It depends on what look you are after.
either the tuff arse '80s skyline, the classic Nissan look, or the ricer punk racer boy
R31 rear shock absorbers and springs will fit the rear end, and will lower it about 30mm ( im pretty sure on this one)
what wheels do you have?? some R31 Ti rims would look ok if they are all polished up etc.
My brother got my FWD Ti pintara rims ( 15 inch solid alloy with slots ) and put the car up on stands, started engine, put into gear and the fronts start spining, (VERY dangerous), he then got sandpaper of various grades and sanded off the clearcoat, then polished up the rims so well they were mirror, looked like chrome! looked shmic...
seat covers always look better than crappy stained seats,
Take out the grille and respray in matt black, a few coats looks good,
go to wreckers , get some nissan bages, polish em up and put on body of car, or debadge the rear end, make sure no glue left...
get detailer to cut & polish up the paintwork, about $100 but worth it. ( & keep it clean too!)
tyre shine on external plastic bumpers, mirrors and window trims brings the whole appearance up a heap.
OLD auto trans fluid is also a good one for window trims.
A chrome exhaust tip
new pinstriping (from auto barn) ( electricians tape is a cheap arse TEMPORARY solution. just to see what its like before you buy the good stuff. elec tape peeles and fades in the sun)
like MAG86 said:
cut and polish for sure, matching seat covers front and rear, clean up the trim.... $100ish
the r31 fronts will work as well to give it the lower stance all round.
depending on what you mean by cheap you could save $$$ by buying r31 sports suspension and use the standard r31 springs and front struts, for about $850 you have good suspension lowered about 30mm and larger front brakes....
i have TRX rims on the HR30 just sprayed black cost $120 + tyres, i just like black rims ???
look for the HR/DR30 tail light, the DR30 ones look more like R31 late model ones, the HR30 look like the standard r30 ones but only the Skyline circle centre lights up... looks cool.... $300ish id say
Edited by rsx84
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
