Hi All,
I just got myself a SERIES TWO R33... and its my 1st turbo car. I'm thinking of getting it up to about 220kw at the wheels.
Can anyone tell me the best way to go about doing this?
Im not sure what cooler to get and what boost control.
I was told by someone to get the GREDDY SPEC M INTERCOOLER KIT and a HKS EVC boost control.
If anyone can help me or direct me in the right direction that would be great.
THANKS HEAPS
https://www.sau.com.au/forums/topic/162377-need-help-getting-my-r33-to-220kw/
To get a genuine 220rwkw you need a larger turbo. The stock one will never make it unless you have someone fudge the result, which is probably the cheapest option for bragging rights
Other than that, read the sticky threads.
I purchased my 33 with the following mods. largish front mount, Turbo back zorst with hiflow cat. pod intake. bleed valve, boost at 9/10 lb. safc2. The car makes around the 180 rwkw at those specs and i am now about to embark on my first round of mods. Stage 3 hiflow, 550cc injectors. better fuel pump. Aftermarket ecu, boost at 18 lb.
Too many peeps too eager to tell me that the setup can make 250 plus. I personally have my doubts unless the dyno numbers are fudged. I am expecting a genuine reading in the 220/230 range. Any more will be a bonus.
Will let you know where it ends up.
God! really? so i need to get a bigger turbo to get my car up to 220kw :D DAMN.....
Anyone in Melbourne know a good workshop to get it all done? Also whats a good cooler and boost control? And what turbo should i go for?
dude hi flow option probly the cheap and the best bang for your bux would be the sliding hi flow stage 3, and EBC choose what ever you want becuase they are all round about the same price. you have the option of Blitz, greaddy, HKS. intercooler well for the power you want even a hybrid would do the job for ya
Check my sig.... Slide Highflow FTW! And I am not even running full boost till I get the computer system in...
Boost controller is a matter of preference.. I love the G-reddy E-01 in my car... doesn't spike and is completely stable.. On the other hand my other car has an E-boost2 - also stable and extremely easy to use.... do some research ..ultimately your the one that has to look at it every day.
www.slidingperformance.com hiflows. get it ordered.
otherwise do what i did to get some more power, spend a good 2,300 and get a Garrett GT3076R fitted. As long as you got a FMIC, form of boost control, and a turbo back exhaust u should be right.
Hi again guys... MAN im sooo confused... This is my 1st turbo car and i dont know much about them....
what things should i be looking 4 when im getting a turbo timer?
Besides looks are they all the same?
You dont need a turbo timer
waste of money
I use mine to leave the air con on without the keys when I duck into the pizza shop for my order................lol. Park it out front where you can see it, set the timer to 9 minutes, take the key out, lock it up and walk in.
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
