Hi All,
I just got myself a SERIES TWO R33... and its my 1st turbo car. I'm thinking of getting it up to about 220kw at the wheels.
Can anyone tell me the best way to go about doing this?
Im not sure what cooler to get and what boost control.
I was told by someone to get the GREDDY SPEC M INTERCOOLER KIT and a HKS EVC boost control.
If anyone can help me or direct me in the right direction that would be great.
THANKS HEAPS
https://www.sau.com.au/forums/topic/162377-need-help-getting-my-r33-to-220kw/
To get a genuine 220rwkw you need a larger turbo. The stock one will never make it unless you have someone fudge the result, which is probably the cheapest option for bragging rights
Other than that, read the sticky threads.
I purchased my 33 with the following mods. largish front mount, Turbo back zorst with hiflow cat. pod intake. bleed valve, boost at 9/10 lb. safc2. The car makes around the 180 rwkw at those specs and i am now about to embark on my first round of mods. Stage 3 hiflow, 550cc injectors. better fuel pump. Aftermarket ecu, boost at 18 lb.
Too many peeps too eager to tell me that the setup can make 250 plus. I personally have my doubts unless the dyno numbers are fudged. I am expecting a genuine reading in the 220/230 range. Any more will be a bonus.
Will let you know where it ends up.
God! really? so i need to get a bigger turbo to get my car up to 220kw :D DAMN.....
Anyone in Melbourne know a good workshop to get it all done? Also whats a good cooler and boost control? And what turbo should i go for?
dude hi flow option probly the cheap and the best bang for your bux would be the sliding hi flow stage 3, and EBC choose what ever you want becuase they are all round about the same price. you have the option of Blitz, greaddy, HKS. intercooler well for the power you want even a hybrid would do the job for ya
Check my sig.... Slide Highflow FTW! And I am not even running full boost till I get the computer system in...
Boost controller is a matter of preference.. I love the G-reddy E-01 in my car... doesn't spike and is completely stable.. On the other hand my other car has an E-boost2 - also stable and extremely easy to use.... do some research ..ultimately your the one that has to look at it every day.
www.slidingperformance.com hiflows. get it ordered.
otherwise do what i did to get some more power, spend a good 2,300 and get a Garrett GT3076R fitted. As long as you got a FMIC, form of boost control, and a turbo back exhaust u should be right.
Hi again guys... MAN im sooo confused... This is my 1st turbo car and i dont know much about them....
what things should i be looking 4 when im getting a turbo timer?
Besides looks are they all the same?
You dont need a turbo timer
waste of money
I use mine to leave the air con on without the keys when I duck into the pizza shop for my order................lol. Park it out front where you can see it, set the timer to 9 minutes, take the key out, lock it up and walk in.
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
    • How complicated is PID boost control? To me it really doesn't seem that difficult. I'm not disputing the core assertion (specialization can be better than general purpose solutions), I'm just saying we're 30+ years removed from the days when transistor budgets were in the thousands and we had to hem and haw about whether there's enough ECC DRAM or enough clock cycles or the interrupt handler can respond fast enough to handle another task. I really struggle to see how a Greddy Profec or an HKS EVC7 or whatever else is somehow a far superior solution to what you get in a Haltech Nexus/Elite ECU. I don't see OEMs spending time on dedicated boost control modules in any car I've ever touched. Is there value to separating out a motor controller or engine controller vs an infotainment module? Of course, those are two completely different tasks with highly divergent requirements. The reason why I cite data sheets, service manuals, etc is because as you have clearly suggested I don't know what I'm doing, can't learn how to do anything correctly, and have never actually done anything myself. So when I do offer advice to people I like to use sources that are not just based off of taking my word for it and can be independently verified by others so it's not just my misinterpretation of a primary source.
