Hi all,
I have struck a problem with installing the RB25 AFM's, on my gtr...currently have Tomie intake.
Bolt pattern is different and so is the size.
Does anyone know who make the adapters?
Has anyone done this recently, the older type air intakes apparently had two flanges....is this correct?
Need an answer by tomorrow.
Thanks in advance
Edited for those who read this in the future.
Justjap imports in NSW has a Adapter to fit a Z32 or RB25 AFM and reduces to 3".....
Cut the original air intake....buy a silicon hose and two clamps 3" and connect them up
https://www.sau.com.au/forums/topic/162381-air-intake-for-a-gtr33/
a few options tekin
#1
use nismo afms. the main problem with twin z32s or twin rb20/rb25s afms is the pipework and ducting etc is 65mm and you need 80mm
so you gotta change it all to suit. the nismo afms are 65mm and same pattern so they bolt up directly. its basically a z32 internal inside a gtr shell
#2
get gtst style pods and throw the airbox setup out. which means pods will probably suck in hot air.
you can get normal gtst stuff as the bolt pattern is the same for the gtst, hence using rb25 afms
a few options tekin
#1
#2
Thanks Paul,
I have Bought Rb25afm,s(Second hand)....How long are the intake pipes on a RB25?...don't have much room.
Then I need to make up special Brackets.
Nismo afm's would be the best bet...don't need to change piping etc.
Who has stock of these?
Why do we do this to ourselfs...... :) ??????????
Constantly wanting more power......getting all flustered and that. :laugh:
Anyone got a set of adapters?
Or Nismo Afm's sitting around.
Why?...Why?,,,Why?
    • Hi soviet_merlin, We appreciate your concern regarding this possibly being some sort of PR/Political hype, I assure you that is not the case, I wish we could claim something like that, but in this case, we merely reached out for comment on the basis of the outrage we too felt, as those heavily in the automotive industry. Ps. the original source in the social media post is CarExpert not CarExplore.    Best, CE.
    • Made a bit of a discovery, but while I was cruising, I randomly decided to test to see if it worked and it showed up on my IC7. The entire time I tested it before, I never thought to turn the ignition on. I only tested it with head lights turned on but with the ignition off. Huge oversight on my end. I’m a dummy. I know.
    • G'day all, I have drilled and tapped the hole for the relocation of the timing belt tensioner. That was straight forward. I'm unsure if I need to also put another hole for the smaller stud that the spring behind the tensioner catches on (this is how it seems to work in its original spot). Or do you not use the spring behind it and just torque it down? Thanks in advance, I did a search but couldn't find anything related and it doesn't mention it in the rb30det sau guide.
    • Hi All,  just thought I would provide an update as I know smooth (Matt) was on this forum from 2003.    my brother Matthew passed away end of may 2024 at the age of 41 from liver failure. I am not sure how many of his original team krazy friends are still on here or active but thought it reasonable to let the forum know.    if you have any photos or pictures it would be great if you could share them.    it took me a while to work out he was active on here.    thanks so much
