I had to buy a new engine a while ago and found a motor with a genuine 32,000km.It looks like a R33 but has the smooth black CAS.This means the CAS drive is also different but thats all.The inlet manifold has the extra barb at the front of it as the R34 does but it also has the metal timing belt cover unlike the plastic one on the R34. It isn`t a Stagea obviously as it didn`t come with 4wd sump.Could it be a laurel or cima? The problem is I`m concerned the cams may be different as I still can`t put more than 15deg. into it at the top end.Have new injectors and GCG turbo and no restrictions anywhere as I custom made the dump pipe so even the waste gate is much bigger than anything you can buy on the shelf.
This motor is frustrating the crap out of me.216kws is not good enough.
https://www.sau.com.au/forums/topic/162407-engine-identification/
I`m reaching the limit of my computer inteligence to be on this amazing forum.But to give you an idea,I was at Bel Garage this afternoon and they couldn`t identify it either.Think of a series 2 R33GTST but with smooth round crank angle sensor in black.People I have been to are:croydon,advan,unique,race solutions and internet everywhere.
It runs great and crisp on the throttle with fantastic fuel consumption.I am ready to pull the cams out just to satisfy my own mind all is ok.I`ve heard the R34 doesn`t really go any different with cam gears but what if it has same cam specs as R33? Those cams have to go.Do I here 260deg Poncams?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
