Hi Guys, my car is gonna get tuned next week at Creatd Motorsports.. just want to know what power i should expect to make.....
I'll be happy with anything over 240....
Vehicle & list of mods as follows:
R33 GTST (manual)
Full reco motor 20,000kms ago
Aries Forged Pistons
New standard Rods
O Ringed Block
Cross drilled crank
Reco Head with standard cams
ACL (i think that was the brand) race bearings
Garret Ball bearing GT 28-71R turbo - 250 - 480 HP rated (1.6ltr - 3.0ltr)
Garret Front mount
3 stainless exhaust, no cats ofcourse
K & N Filter
Microtech ecu
Car will be tuned on whatever boost the turbo stops making more power.. so im guessing around the 15-20psi mark..
Let me know what u fanatics think... :happy:
Edited by Dean_HR31
https://www.sau.com.au/forums/topic/162423-what-power-do-i-expect-to-make/
yehh, i just want a quick, responsive street drift car... In my old r33 200rwkws just didnt cut it for drifting in the dry... second gear was happy but not
loose enough.. just needed those extra kw's to allow for more throttle play...
oh sorry and im also running a profec B spec 11..... :happy:
Can anyone give me any info on what kw's this tbo will push out at the wheels on an rb25?
Edited by Dean_HR31
ok anything else...?? Has anyone ran this kinda turbo on big boost before on an RB25 and can tell me what it was like..?
Im sorry i just want to know everything cos i cant bloody wait till the car is tuned... :laugh:
    • Well some mostly good news and some slight bad news.  Good news is cylinder 6 did in fact only require a honing and I'm good to run my 86.5mm pistons again. I should also get the block back by end of week. Bad news, had a few surprises pop up. First, main and rod bearings were trashed. No sign of any heat damage. I knew right away what caused this... I had not packed my oil pump originally and spent a lot more time than I would have liked cranking the motor to get oil pressure. It sounded fine once started so I chucked it up to luck and forgot about it. Luckily rod and crank are fine and just need new bearings. Engine builder agreed that this was the cause.    Another surprise that carbon covered up very well that I didn't catch, something got sucked up and went through cylinder 1, 2 and 3. Luckily this was no cause for concern, just needed a bit of cleaning up. Valves look fine but he will vacuum test the head this week to confirm. I'm presuming this was something left over from welding my intercooler piping, but we'll never know. I'm going to thoroughly reclean everything.    So all in all, happy the motor is fine, and I'll get it back much sooner than expected. I'll also be taking the time to convert my WMI system over to direct port. I'll snap some pictures of that when the parts come in.
    • I understand, thanks. Yeah I wouldn't want the car to tip over, I'll try and use the sills, I don't want to risk smashing the chassis rails. I ordered some rubber pucks that have a hopefully big enough slotting. If the front right gives me trouble I can always just make a wood block. I'll measure and inspect the sills closer once I actually take the car up. I hope so, but the rubber blocks I had in hand so far were pretty damn firm, if they are that hard they won't give much way. I'll let you know what happens. Angle grinding rubber isn't one of my favorite tasks. I'll probably start a build thread soon, for my own documentation and "log" as well as sharing what's going on with the car.
    • Kinda something I have been thinking about.  To be honest, we bought it already driving like that.  So there's no telling how long it actually has been driving like this.  Hopefully damage is too bad when we drop the pan.   I am having a hard time finding a site that sells the solenoid for the 5 speed auto, do you have any suggestions?
    • That'll be most likely down the road...  LOL
    • a stock / option or aftermarket?
