Just recently had a new deck, sub and amps installed into my Stagea by someone recommended by the shop. I used Install All in Wangara and was very impressed.
Received really good service and advice and the quality was excellent.
Also installed new alarm system with extra features that were a surprise.
Would recommend him to anyone.
I told the owner, Marty that I would post something on the forum (which I put him onto) about the experience, so here it is.
His contact details are:
[email protected] or 0419 990 070
Cheers Al
https://www.sau.com.au/forums/topic/162432-stereo-install/
Cheers Al
im looking to get some stuff install ill check it out
Edited by blinko
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017075
one for the consolidated workshop thread perhaps?
Dan maybe you should leave it open so people can put their recommendations in there (unless there's just way too many)... positive comments only of course :happy:
i'll need to put some rear speakers, amp and sub sometime soon...
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017130
I ask Dan to open the thread for my updates every now and then. I got a very long PM from a member called 260tech about a company called Tunetech, a little more info than I needed but they seem to do a fairly good job.
I have these guys and Install All to add at the moment, I just need specific addresses etc and things like, whether full customisation is available.....
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017504
Topaz
Details for Install All are as follows:
Install All
Unit 8
53 Prindiville Drive, Wangara WA
Ph: 0419 990 070
Email: [email protected]
According to his business card he does Audio/Visual Systems, Alarms, Immobiisers, Mobile Hands Free Kits, System Design, Spot Lights, Electric Boot Release, Electric Windows, HiFi Wireups, Central Door Locking and Reversing Sensors
Hope that helps
Cheers, Al
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3019947
leon poppovich ftw !!!
one of the best out there for custom install high end stuff :)
Ahhh yes i remember have my skyline next to his supra in the car show all those years ago, his supra was decked out and completely ahead of its time.
Where is he working these days? i heard he was helping to some special lambo kit cars or something??
Yep would definately recommend Leon!
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3021242
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
