Just recently had a new deck, sub and amps installed into my Stagea by someone recommended by the shop. I used Install All in Wangara and was very impressed.
Received really good service and advice and the quality was excellent.
Also installed new alarm system with extra features that were a surprise.
Would recommend him to anyone.
I told the owner, Marty that I would post something on the forum (which I put him onto) about the experience, so here it is.
His contact details are:
[email protected] or 0419 990 070
Cheers Al
https://www.sau.com.au/forums/topic/162432-stereo-install/
Cheers Al
im looking to get some stuff install ill check it out
Edited by blinko
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017075
one for the consolidated workshop thread perhaps?
Dan maybe you should leave it open so people can put their recommendations in there (unless there's just way too many)... positive comments only of course :happy:
i'll need to put some rear speakers, amp and sub sometime soon...
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017130
I ask Dan to open the thread for my updates every now and then. I got a very long PM from a member called 260tech about a company called Tunetech, a little more info than I needed but they seem to do a fairly good job.
I have these guys and Install All to add at the moment, I just need specific addresses etc and things like, whether full customisation is available.....
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3017504
Topaz
Details for Install All are as follows:
Install All
Unit 8
53 Prindiville Drive, Wangara WA
Ph: 0419 990 070
Email: [email protected]
According to his business card he does Audio/Visual Systems, Alarms, Immobiisers, Mobile Hands Free Kits, System Design, Spot Lights, Electric Boot Release, Electric Windows, HiFi Wireups, Central Door Locking and Reversing Sensors
Hope that helps
Cheers, Al
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3019947
leon poppovich ftw !!!
one of the best out there for custom install high end stuff :)
Ahhh yes i remember have my skyline next to his supra in the car show all those years ago, his supra was decked out and completely ahead of its time.
Where is he working these days? i heard he was helping to some special lambo kit cars or something??
Yep would definately recommend Leon!
https://www.sau.com.au/forums/topic/162432-stereo-install/#findComment-3021242
    • To be fair passengers who aren't silly and have been in proper fast cars have often been pretty impressed once you hit 4th gear
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
