Hi!
Here is my setup:
rb30det
040 fuel pump
stock everything(exhaust)
3.9 final gear
205/55/r16 tires
I was trying out my car today. My friend had my mobile with countdown timer , so he was sitting in the passenger seat, counting.
With moderate spin from start - high 9sec to 100.
Feels quick, but timer spoils the fun LOL.
I even tried to use 2nd gear(no upshift to 3rd) to 100. Same result.
Surface was a bit rough. Asphalt covered with dust.
What I was able to see though, that in 1,2,3 gear after about 5-6k the boost gauge needle drops from stock 0.7 to 0.5. Maybe a bit earlier. But I can't say for sure. Car Idles fine. No jumpy revs.
No leaks after AFM/before turbo.
So what's causing this boost drop ?
And what about acceleration ? I think it should be in 8sec range.
Thanks!
Edited by robots
Thats how the stock RB20 turbo/actuator is dude.
You need a stronger actuator, or a larger turbo (well.. both would be ideal).
The little RB20 turbo does have a fair task on its hands :happy:
R31Nismoid, c'mon.
It can't be 9-10 sec to 100.
Something ain't right there. It should be around 8sec mark.
I have stock exhaust btw. So where should I dig ? Gap the plugs to 0.8 ? Clean coils ? Try manual boost controller ?
    • Meanwhile, 20+ years ago, I pulled out the 105mm hole saw and went straight down through the inner guard in front of the airbox to get my stormwater pipe cold air intake in. Right behind the two stock holes for the intercooler pipes. Those have no reinforcement (apart from a couple of robust pieces of steel pipe through them!). I feel that the Australian vehicle standards crews put way too much emphasis on "maintaining the crash performance" of cars and not enough consideration of "any crash is a new and wonderful experiment with a random selection of parameters and you will never be able to tell if an extra 80mm hole through some sheet metal caused a significant difference...but if you close your eyes and squint at the whole structure, engage your engineering brain and have a good think about it, you'd have to expect that it would do jack all."
    • You guys are focussing on the wrong part of this post and have headed off on an irrelevant tangent!  Clearly I'm not going to put my most prized physical possession (well it will be once I'm finished it...) on a piece of shit contraption that might fail and crush me or my car!  At no point was that even implied I was trying to buy a butchered P.O.S that some shonky clown had thrown together with a gasless MIG....  Either way I would love to see the build quality of a rotisserie that has failed.  Actually I'd love to see a photo of one that has failed full stop.  Google fails to deliver.  Never happened?? I'll either make one that won't fail or will buy one that wouldn't fail! End Post.....
    • Yeah, if you can't breathe for more than about 2 minutes, you're cooked.
    • Well, all the power should be getting dissipated across the starter motor. Therefore, ideally, the voltage drop across the earth lead should be convincingly close to zero. Certainly you'd want it to be only a volt or so at max, because otherwise that volt doesn't turn up at the starter to do what is required. A car can probably survive a bad enough earth to crank and start with only 9V or so at the starter motor, maybe even a bit less. But you're seeing only 8V at the battery terminals when cranking, so there can't even be that much available over at the starter, which simply won't do. I would have thought that you couldn't pull enough current (with a healthy starter) to make the battery drop to 8V locally. But I was ignoring the possibility that the starter is in fact crook. If it has shorted windings (or maybe the solenoid is borked and shorting to earth) then I guess it could pull a stack of current and not even look like wanting to turn over. So follow the other boys' reccos too. Because they are just as likely at this point.
    • Depending where the whole gets drilled, and what country/state you're talking about, quite likely not.   Under ole vehicle mod rules in NSW, VSI06 allowed for drilling of holes in "non structural" areas. So you could drill a hole through the inner guard, and not need engineering. You couldn't drill over seams, and it was advised to add extra reinforcing around the hole, as well as something to protect from sharp edges.   Again, it's all about finding the documentation for where the mod is to be done, AND then being able to explain the situation, with the documentation as to why you don't need engineering, with a positive attitude, to any one of the likes eg, police, vehicle inspector, etc.
