  • Replies 54
Bill Russo is in Court today from 10:30 to hear the judges decision over AIR. I have been asked to go to Court with him but cant make it today. I will post the result as soon as I hear.
Terry
*crosses fingers*
Ps cheers for the clutch delivery service yesterday!
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3017467
Just spoke with Bill, he did not win the case but has already put in for an appeal which could take up to 6 months. there is a few key points that he can appeal against. The judge decided that the contract to purchase the track did not exist but whilst on the stand Rodney Jane admited that there was a contract and that he didnt care who he sold the track to.
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3018557
^^^ ;) He's from QLD so give him a break & what's PS?......j/k
To help sway the next judge's decision maybe a letter w/ signed petition to the minister of transport would be in order, stating that it would be in the best interest of the motorsport community & the community in general if A.I.R were to be owned by B Russo.
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3018726
how about Bob f**king Jane pulls his finger out of his ass and fixes up the track himself so we can race? Surely someone knows him and can get him to look at this thread and all the others on the many motorsport forums to see the damage he has done to our fun.
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3018898
yup
to keep illegal draggings off the street
saves lives imo
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3019021
yeah i dont want bob jane owning it any more he never put a cent into the track ....
look @ who owns WSID theve got an imaculate track and facilities
why shouldnt we have the same they charge us entry prices like we do its about time we got something nice
/edit
im +1 for physically signing a partition to send to the judge for any good its worth if all the clubs around SA did this it might be wroth something
imagine the judge when faces with 1000 signatures from skyline clubs mazda clubs toyota , holden ford the rest anyways now im rambling
Edited by Madaz
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3019718
:):P:rofl::rofl:
PS - Whats a skyline?
Lol isn't it one of those silvia's but better?????????????
I have to say this is getting out of hand. This court crap has gone on long enough. I can't understand why the Judge is continuly denying Bill the raceway.
Oh and Thanks uncle Terry or helping me with the bigger/ better brakes.
Now time to get a petition for the track organised.
https://www.sau.com.au/forums/topic/162456-news-flash-air/#findComment-3019743
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
