Hey guys,
The RB20DET in my HR31 won't rev past 2000rpm. If I drive it has to be kept below 2000rpm otherwise it wont accel. When it gets to 2000rpm it coughs and splutters and it almost seems like its a rev limiter. It bounces like a rev limiter. I have swapped the AFM and Ignitor from my A31 Cefiro to no success. I have sprayed all plugs I could reach with contact spray. Anyone have any ideas what this problem could be?
Thanks, Chris.
https://www.sau.com.au/forums/topic/162463-rb20det-wont-rev-past-2000rpm/
Swapped a good know AFM from my ceffy onto the HR31. Made no difference. Swapped known good ignitor also from said cefiro and also made no difference. Intake pipe is on tight. CAS plug is on tight. Have had battery disconnected also for 10mins, still no change. Tried putting ecu into dianistic mode now engine wont start at all? ECU?
I bought a 32 a couple of weeks ago, and it had the same problem. Fine below 2 grand, but coughed and spluttered its arse off at anything over that, and got worse the more you put your foot into it. (Although mine didnt bounce like it was on rev limiter, and I could slowly, slowly accelerate). I changed both the AFM and Crank Angle Sensor with no better results.
Turned out to be the fuel pump. I got that changed over and everything was fine.
Might be worth a quick check
  • 2 months later...
Just in case anyone else checks this thread for an answer...
My mate limped his R32 RB20det over to my house tonight with a 2000rpm rev limiter.
We found after checking AFM, Throttle position sensor, and cooler piping etc that it was an Air Fuel gauge had been wired in real dodgy!
Disconected the dodgy wire from where someone had spliced it just near the ECU and all is well again!
Cheers
    • @DraftySquash @Duncan he's not talking about the part that sits against the radiator support, he’s talking about the lip that sits towards the front outside of the car. anyway I had a look at other cooling panels and came across this one https://justjap.com/products/carbing-radiator-cooling-panel-plate-nissan-skyline-r34-gt-t?variant=37829684134087&currency=AUD&utm_source=google&utm_medium=organic&utm_campaign=Advanced feed&utm_content=Carbing Radiator Cooling Panel Plate fits Nissan Skyline R34 GT-T (Coupe)&srsltid=AfmBOoonzPDKqe9NgKi5U0AkFc2XvbXETGmNWvfNcyBT5DUZagMYHg9DZ70 if you take notice it’s the same shape.  well thankfully the justjap listing has a description and it says : - Nissan Skyline R34 GT-T Coupe (M/T -07/2000) this means it’s specifically for a s2. S2’s have different front bars to s1 so that lip with the 3 holes are *probably* mounting points for the s2 bar. im not 100% sure but im almost certain it will still fit a s1 bar
    • Everyone is too used to learning from places like HPA "how to tune" and what to expect at what point, rather than being able to see "The computer says I'm in cell with Row = 8, column =4, and I can see my fuel is lean, so lets add more" Everyone wants "real units", which helps for someone picking it up for the first time and seeing how bad the tune is if they're not used to touching it.   However, I think for most of us who want to play with it, you're 100% right, we're only needing to learn about it for OUR CAR. Which makes it great, and we don't need to care what the real values are, we just need to know which cell it is, that's causing the lean or rich point, or that we want more ignition timing or less. But again, everyone wants everything super you beaut and nearly self tuning, with VE maps, and a billion compensations...   Though then there's me over here when I'm doing reverse engineering work just reading data in hex format that most people couldn't work anything out from. Yet I can see what's going on.
