ive seen this car on the road in eltham a few times now and bloody wet me self each time it drove past :huh: .
does any body know him, if not i was hopeing to give him a SAU flyer (of some sort) but hes selling the car.
can i have $155000 plz SAU?
http://www.carsales.com.au/used-cars/priva...7&trecs=947
https://www.sau.com.au/forums/topic/162498-this-car-is-sweet/
  Mean_R34 said:
He reckons he buys/sells every 10-12 months.
Lucky bugger. He also paid considerably more than $155k too.
BTW, that was his 4th R34 GTR.
i heard/ read somewhere that his is the only one in Australia??? maybe it was Vic?? anyone know..
yeah seen him eltham too. think he use to have a blue 34gtr (saw it lurking out of a driveway one day.. i just about crashed)
  Nismo Racer said:
Group Buy!
hehehe reminds me of the episode in the simpsons where bart, milhouse and martin buy that special edition of radio active man.....the group buy didnt work for them....a group buy with 40,000 members and one car will def work though hehehe...
Id like to see it make it through all 40k members without getting totaled. That would be an effort in itself :P
Yeah it is.
He also did have a BNR34 Bayside blue.
  R-SPEC said:
yeah if only i had a cool 150 layin around....
i'd give this guy a call
http://www.carsales.com.au/used-cars/priva...e|1&trecs=3
thatd be a tough choice......both are rare - though the 34gtr would be rarer in this case....and newer
yeah i guess some will have trouble deciding.
i wouldn't need to think twice bout it :(
at the end of the day its just a skyline compared to a car like a ferrari. tiz to me anyway >_<
Edited by R-SPEC
    • Hi all. I am aware there is lots of discussions about jacking points, where to lift the car and what not. But as usual just a lot of "in my opinion" and nothing definitive, and everyone does it in a different way. I want to hear from some experienced people on which points on the car it's okay/safe/recommended to lift the car using a four point hoist/lift. I will attach some images of my underbody. Sills are largely okayish, the driver side jacking point is pretty mangled though and it looks like the underfloor is slightly pushed in too, but I might be wrong. In the German Skyline forum, the consensus is to use the sidemember chassis rails in the front and the rear subframe? bushing in the rear. I know the manual says to never use the sidemember for loading but lots of folk do it and it was definitely done on my car too as they are slightly bent too. Based on the images, what points do I use to not make the already present damage worse? I'd use wood or rubber blocks to spread the load across a bigger area of course. Driver side sidemember and jacking point mangled one) https://imgur.com/a/eKjzrJX Driver side rear jacking point https://imgur.com/a/W3DWF1P Passenger side sidemember and jacking point https://imgur.com/a/65UvIJe Passenger side rear jacking point https://imgur.com/a/h3k7j53 We can also see some underbody rust but so far it all looks somewhat treatable and nothing that requires a Yoshida style restoration.
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
