Ehh Guys I was wondering if you would be interested in meeting up at my work???
Its a pizza shop with alot of nice food to settle your stomach :D
I was thinkin around 9ish, we can eat food and later go for a little drive of something.
Let me know what you guys think, whether its a good or bad idea.
Take it Easy
:uh-huh:
https://www.sau.com.au/forums/topic/16251-meet-up-on-the-24th/
  • Replies 64
Hi Guy's yeah Sunday is good for me, although our shop closes at 10pm on sunday so it would be good for you guy's to come around at 8ish then there will be heaps of time for food and later a lil cruiz.
:uh-huh:
The Pizza shop is on Princess HWY in Beaconsfield, it is opposite the Beaconsfield pub and next to Tacho Bill.
From Narre Warren La Porchetta its about 7mins away.
And Dont worry I wont poison ur pizza's!
/me goes to check events section.
I may be able to come not sure yet, the in-laws are auctioning there house on sunday...they may be celebratin that night...I will have to wait n see if i can go, sounds good though!
:uh-huh:
"what do we get if we've been good?"
"pizza"
"what do we get if we've been bad?"
"poison"
"what do we get if one of us has been good and the other one has been bad?"
"poisoned pizza man!"
"Oh no Im not making 2 stops!"
LOLz!!
yer Im up for a pizza cruise on sunday...just let me know where we are meeting up etc and Im there, but now Im rolling on 17s....
Hopefully my car will be back together by then, if so i will come.
Car was stripped to tint windows and now i am adding in an amp and some other minor modifications :D. Everthing from the front seats back has been pulled out, looks like i am getting ready for the drags :P.
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
