I need help !
I'm changing my shocks and springs and need to know the standard ride height of a R33 GTS-t.
So if someone with standard suspension can mesure up their car from the centre of the wheel to the lip of the guard (front and back) it'd be great. And if you could just take not on how much fuel you have in the tank when you mesure it too....
I mesured up Shell car (thanks Shell :) ) but I just want to double check cause I've been told something different to what I messured :)
Shell's car got 365mm front and back with a full tank.
ATM mine mesures 355 at the back, and 335 front - but has coilovers, so it ain't stock :D
Thanks
Jayson
No probs Jay :P
if you need it for anything else, just give us a yell...
and just FYI, it was closer to half a tank than a full one (i had a qik look at the fuel guage when i drove off)...musta used more fuel than i thought...
Shell - you used that 1/2 a tank of doing burnouts I bet :)
Ken - thanks for that, so that's 376 front, and 363 rear.
I'm aiming for about 355 front and rear. The other car that was measured up was 375 rear and 365 front, so I think the rear springs tend to sag a little over time, or are pretty soft so are easily dropped depending on the fuel etc....
Thanks
Jayson
Jay, i will do it tomorrow for you. Just remember though, that even stockers are different; depends on the wheel/tyre combo. I'll post that too when i measure it
I have stock 16" rims, suspension and 205 tyres... cant remember the profile but will check it tomorrow.
OK, just measured it:
Ft: 355mm
Rr: 355mm
Half tank. No occupants :(
205/55 tyres. Stock suspension. Hope that helps.
Thanks for the replies everyone.
I've worked it all out and ordered the new springs.
After having a chat to NDR and to Jackie at whiteline (who sounds hot !!!) I figured out that the whiteline stage 1 springs drop the car to 345mm. The springs are 35mm lower springs. So that works out that the stock ride height is 380mm (we're talking about NEW stock springs here :) ).
I only want to drop it 25mm, so I had to go the KMAC's cause whiteline only have 35mm+ ;)
Jayson
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
    • Right, but if you replace the pump gears + put a spline or sine drive gear on the crank on a Nismo/OEM/N1/etc pump at that point do you really still want more flow/oil pressure? Let's say this is a the aforementioned "keep it simple" build, no more than ~400 kW at the crank.
