Looking to swap my r33 for a cheep reliable manual car, buying a house and cant keep my hobbie up atm.
its a 1994 r33 gts,
74xxx kms on the clock
I imported it in 2 years ago dead stock have since done
Added an r32 turbo running r33 wastegate actuator running 6.5psi boost
stock side mount intercooler
malpassii rising rate fuel regulator
pod filter
2 1/4 cat back exhaust
excedy heavy duty clutch
whiteline strut brace
microtech lt12s
ab flug series 2 front bar and r32 ab flug side skirts
roh mantis shadow chrome 17" rims
warwick alarm and remote central locking
reasonably decent stereo system
autometer boost and air fuel gauge
600hp fuel pump wallbro i think cant remember
turbosmart bleed valve never boosted put it on was going to run 9 psi but tuner decided
r32 turbo wasnt worth boosting as i was going to rebuild and high flow my spare 33 turbo
and re-tune it then, so it was a better idea me getting used to the power at 6.5 psi as originally
i had never driven a turbo car
gun metal grey
this thing has no lag and pulls right threw the rev range
have had it dynoed by two different places one said 130 at the wheels the other said 150
tunned a little richer than optimum because of the high comp motor and stock intercooler
With upgraded injectors, high flow r33 turbo and front mount and re-tune could easily hit
200 at the wheels and still have next to no lag, very fun to drive will miss a lot
Also have spare parts to be sold with the car
4 original rims with tyres with 50% tread
stock front bar
full Na induction system resinator air box ecu
Na front pipe and exhaust manifold
r33 turbo with blown oil seal (bought it second hand only to find oil seal was f*ked but ey no shaft play grrr)
r32 10psi wastegate actuator
r33 turbo elbow
oil cooler and lines mounted on the car but decided to run my oil lines differently so was only fitted for a week
oil lines would need to be run differently as set-up is different than what it originally was
na ecu
Located in melbourne
price $13,000 but more interested in swap for a cheap reliable manual car and cash adjustment
Email: [email protected]
or just pm me
Edited by unarmed_skyline
https://www.sau.com.au/forums/topic/162535-1994-r33-gts-nat/
com'on this car is heaps of fun to drive, im willing to sell it as na for 10K if anyone is interested still very quick when na
i only give the car a bit of a squirt every now and agian so it hasnt had a hard life,
  • 4 weeks later...
