hey, im looking at trading my laurel for a 4 door r32. maybe another slider.
my laurel has jic fully adjustable coilovers, cartor arms, camber tops, front and rear sway bars, kaaz 2way lsd, short shifter, fresh rb20det silver top (has done 100, 000k's) rebuilt r32 turbo. (no shaft play) fmic, nardi wheel. blitz bov, z32 airflow meter,blitz pod, 3 inch zorst. car is set up for sliding. has new roof lining new carpets, current has a ceffy passnger seat and a pro bucket seat on bride rails, car is mod plated for 2 people but has mint rear seats aswel canbe mod plated for 4 people. head unit and speakers.
I love the car, but not as much as r32 four doors.
car does not have AC. (as it was removed by previous owner...stooge)
car was darren appltons old laurel, not the purple one but the 2 tone pear white. as seen in HPI.
im located on the sunshine coast, car is registerd till august.
contact me on my email [email protected], or pm me
https://www.sau.com.au/forums/topic/162544-c33-laurel-rb20det-manual/
It should have a white vinyl dash signed by izumida and another D1 driver if Im not mistaken......
If so thats deff. Afros old ride.
unless that was the purple one? :blink::wave:
And it should also have a big dent in the passenger rear quarter panel, if it hasn't been fixed yet. the dent was put there when i owned it :wub: It should also have some of the dash painted white. I originaly bought it of Darren :stupid: Good luck with the sale anyway. Matty
Edited by Mr Laurel
yer, its got signatures of the d1 drivers. no majour dings in the car, dads mate took all the dings out. looks mint, aswell as most of the interiour been replaced, new carpets, roof, and etc.
im more so after a trade for a r32 4 door, must have most drift mods, coilovers, 2way, front mount.
may sell it...
just in the middle of puttin a fresh rb20det in it, should be done on the weekend, maybe early next week,
just put a new excedy heavy duty clutch in aswell as new turbo water lines.
  • 2 months later...
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
