I've always been a bit sceptical about that one, even though its been raised in a few threads. Plastic and cut & polish generally doesn't go together, so i wasn't going to rush out and try it without good reason.
Anyway, i got a bit of scratch on my headlight (ouch).. so i thought, crap.. what do i do, don't wanna spend $200 on a new headlight? So i remember these threads, and thought as a last resort worth a try. So i whipped out a tin of the cut & polish and see whether what it would do. !!MAGIC!! Cleaned up that scratch, and a lot of the smaller scratches and things. Best of all it cleaned all this murky stuff which i could have sworn was inside the headlight.. but now its all gone. Now they are all pretty crystal clear, which is good for both looks during the day, and headlight visibility.
Be a bit careful, i wouldn't leave it to stay on there too long (more than 10secs) before wiping it off with a cloth. It may leave some small hairline swirls, but overall its so much better. I was so surprised how well it worked.
Only prob is then you discover all the other little things that are *inside* the headlight - unfortunately the process to fix that is pretty damn difficult. You gotta actually split the whole assembly.. then reglue it all up..that is if you haven't shattered or chipped something in the process (likely)
Hey guys.
How easy was it to acutally take off your headlight covers?
Just a couple of screws or is it a clip-on job?
They can't actually be removed .. if u do you have to fully split them and reseal (a tricky process). We're talking about the outside - which can make a big difference to the overall look/clarity.
Gave it a go last night, came up well. Meguires fine cut. They have a fairly extensive range, anyone use there other products, just want to know as it is quite expensive and don't want to fork out for a trial! Are they as good as their price tag suggests?
I believe that Meguiars is worth the money you pay. It can be a bit of an outlay intially but I find that you will get a fair bit out of each bottle.
I use their wash gel, fine cut cleaner, glaze, canuba (spelling?!) wax, plastic and vinyl conditioner (inside) and the long lasting tyre stuff.
Obviously the cut and polish stuff lasts longer because I dont use it all the time but its prolly good for about 6 jobs. The tyre stuff has gone longer than the suggested number of uses on the bottle and the plastic cleaner is waayyy better than Armoural IMHO.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
