...r31 skylines that is!
check out this in car vid from a drift day at oran park
take one 5 speed r31
lock the diff
strip the interior (for no reason at all)
bit of an exhaust
some firm shocks
and you're set
if a rb30e skyline can do this, then the boys with later model skylines should have a ball at oran park
get out there for the sau nsw drift day
non sau members - http://www.skylinesaustralia.com/forums/in...howtopic=157562
members - http://www.skylinesaustralia.com/forums/in...howtopic=157560
https://www.sau.com.au/forums/topic/162550-skylines-are-the-best/
I feel that maybe a challenge has been layed down for the mighty R31 wagon! Could just be the first R31 wagon drifter! You make it sound so easy with the minimal mods.
sorry brave, you're about 3 years too late :( pete had a red wagon a few years ago. from memory it was SR20 turbo power...
and trust33, forget the shims, when we say R31 locked diff, we mean welded diff. get the mig out, crank up the power and away you go. :(
(unless you are talking about any car other than a R31. if that's the case do not weld your diff!)
oh, and 31s bite the weiner hard. I had a silhouette it was good for burnouts, and even sounded ok, but that was it. the piece of shit ws rusting and falling apart.
R31 on it's farewell burnout. even chips second... lol noice.
http://www.skylinesaustralia.com/forums/uploads/MOV00638.MPG
umm, you have to right click save as for some stupid reason.
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
    • Howdy all,   I had my rb25det S2 rebuilt and finally started it today but have run into a few issues  Engine sounds like a a diesel easiest way to summarise like small ticking, gets louder when revs are slightly adjusted  The engine builder repainted the engine cover leaving no where for me to go off with lining up the CAS so have it as central as possible so not sure it that could be affecting it?, changed the gearbox fluid too but won’t seem to go into gear when running, and only 1 to 4 when off having a hard time finding 5th and reverse anyone got any ideas or a base for me to start off? much appreciated
