Im looking to buy some projector headlights for my R33.Ive found a site that sells them but its a bit pricey.Any idea where i might be able to find some at a cheaper price.
I think Nismo made some for the R33 too.
here is the site if anyone is interested.
http://www.istoreparts.com/lighting-headli...-c-249_339.html
https://www.sau.com.au/forums/topic/162552-r33-hid-projector-headlights/
they are series 3 gtr r33 headlights. look so nice! but yes. very pricey. can source some second hand from japan for a grand or so.
Thanks for the info,1k is better than 2k.Ill look into it.
best bet would be a retrofit. If you notice, the GTR SIII headlights are a very simple shape. It is as if nissan got the sI housing, ripped all the crap out, put in sII shaped reflector for highbeam, put a projector in the low beam and put a bezel around it.
I was gonna make a couple sets for giggles and bragging rights last holidays, but I was busy with other commitments. Maybe this christmas if I can find some cheap headlights again (there were so many last christmas).
  • 2 months later...
I have pulled an S1 headlight apart and tried to put a projector out of a broken HR31 headlight into it, but the projector assembly is too long! The housing isn't deep enough and the mounting points to adjust it were too difficult to line up. Then you would have to fabricate a housing to surround the glass. I want the projectors as i have HID's and they're a bit glarey for oncoming traffic.
If anyone wishes to make a set i would be interested!!!!
oh and can anyone confirm that the only outer difference in the S1 and S2 headlight is just the clear plastic lense and not the backing?
i have also researched into this mod, theres info here and there, but i dont even know what projector bulb to start with. maybe later down the track ill see if i can get a pro to do it for me. i cant really justify the cost of s3 lights, guards bonnet, grill and whatever else needs to be changed.
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
    • I would agree, unless you need something specific to the HV motor/battery side repaired or investigated, any mechanic will be able to perform normal services, but if you prefer, maybe look for a mechanic who regularly services/repairs Nissans, the VQ engines are pretty common in the Nissan lineup.  Sorry, I can't make any suggestions, I don't live in Vic.
    • Some of them keep working fine. 9 out of 10 of them end up causing an absolute misery bleeding the system and get thrown on the workshop floor in a tantrum and never thought about again because they were never really needed and just added crap to the car that we could have done without. Same-same with HICAS, A-LSD, and various other stupidities that over eager 10x engineers thought we had to have.
