Is It Safe To Run 92% Duty Cycle On Stock Injectors
When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
I dunno what the "best" one is....but when my 040 died late last year, after about 20 years of screaming service....I put in a 255. Like any such thing, you have to finagle it a little bit - it's not a no-brain swap. But it's not hard.
Not yet. The current 45mm Gen 4 gate is already a tight fit. I don't think the EWG 40mm is going to squeeze in that spacing.
