Selling a 92 sr20det 180sx. Spun a bearing at calder, cant be bothered fixing it, so looking to sell it.
The car has done 130ks, and had 230kw at the wheels, have dyno sheet to prove it.
The car has:
gt2540 turbo
555 sard injectors
AVO front mount intercooler
bosch 040 fuel pump
remap ECU done by Dr Drift
lowered springs
carbon fibre gt wing
full vertex bodykit
18 inch lenso concept 5s
momo steering
autometer boost gauge
I have all the receipts to all the parts in the car. The car has new paint and is really a head turner. What it needs is either a rebuild or a new engine.
the only thing i'm taking out is my Bride seat and my head unit. I will put a stock seat and another head unit back in.
NOW ASKING 9K AUD FIRM
Car is in Melbourne.
Contact me @ 0413184780
cheers
Edited by xion13
more pics of car
As i said before, the car DOES NOT come with the seat and head unit but will be replaced with a stock seat and another head unit instead.
open to all offers.
Edited by xion13
bump bump
please buy this.. fyi to fix it a rebuild will cost around 4 grand but an engine swap will cost 2.5 grand.
this is including labour. everything i can arrange for you.
i can arrange a tow for you as well if you want the car elsewhere.
hurry hurry i got another car waiting
9 grand is freaking cheap IMO...
    • Hey guys been looking everywhere to try and find the correct gtr hood latch support part number but only found the first half and when I search with that number it sends me to an r34. The first part I found was 62515. If anyone could help me with the rest then I’d really appreciate it. Or if there’s some alternative hood latch support that would work even better cause I can’t find any for sale. (Searched on upgarage, partsouq,buyee,rhdjapan)
    • If you've only done the upper control arms on the rear, AND you have changed their length (by more than about 1mm) to set the camber you want, then you will definitely need/want to install traction arms also. Adjusting the camber arms on their own WILL introduce bump steer and make the car unpleasant to drive. Most owners have no idea that their car could behave infinitely better than what they put up with. I'm not entirely sure what the Stageas need, but I am thinking that unless you have massive front spring rates and pretty soft rear springs, you have waaaay too much rear bar. Oversteer city, in my estimation. Combined with possible excessive bump steer from maladjusted arms, that could be a recipe for nastiness. ATR43SS2 is not a highflow. It is an outright replacement turbo. It's a little bit bigger than the largest highflow profile that Tao does. Probably a solid 300rwkW turbo where the bigger highflows will be about 30-40rwkW less. Nevertheless, we're only talking about ~300 rwkW, which is well within the abilities of the stock ECu to run with a Nistune on board. I would do so without hesitation - and I will be doing so when I get my finger out and actually get the injectors and AFM installed. But, if you would prefer to drop a whole lot more money on the ECU side, then I suspect you're looking at Haltech. The Haltech fanbois here will all spout on about all the available engine protection you can have, that you can't have with the Nistune option. And they're right. But it doesn't really come for free either. You will spend more money on extra sensors and the like, plus the work to install them. If the engine was built and therefore represented a big investment to protect, then I'd say definitely do it. If you view the current (and forever into the future) shortage of replacement engines as something to prompt similar protection, then also, do it. If you see a destroyed RB25 as an opportunity to put in a Mercedes or other V12 (like I kinda do)... then your perception of the risk/reward might differ. These are good injectors. You can also get a "better" set of the same with more flow matching, for more $$. 1000cc is where you will want to be. You will need an R35 AFM and adapter tube if you want to stay with Nistuned stock ECU. Otherwise, if going Haltech, you can ignore. As for intercooler. Just about anything will do. You're only talking about ~300rwkW. Just put a big core in there. Be aware that return flows do add significant pressure drop and will cost power and will make the turbo work harder to achieve the same goals. If you can manage a proper crossflow, do it. I'm keeping my very good return flow because I'm only expecting to be in the ~250rwkW range, and will live with whatever outcome I get.
    • I have a heap that i have collected if you want some authentic ones still. Pm me if your interested!
