Price change.
$225 including shipping.
Hi,
I am selling R32 GTSt clear indicators.
There are curently 12 pairs for sale.
Delivery is expected in 4 weeks.
Pre order yours today for $225 including delivery or $215 for pickup in Melbourne only.
Price when landed in 4 weeks will be $250 if still some available.
I encorouge pre ordering if you have been looking for these for a while. I know I have.
Items are being sourced through Drift Line.
Please PM me to order.
This is a group buy underwritten by me to ensure that others dont miss out on these indicators. They are very rare and ive been looking for them for ages. I curently have 12 left for sale.
Thanks.
Adam
Please not this post has now been modified to fit with the group buy rules.
https://www.sau.com.au/forums/topic/162607-r32-gtst-clear-indicators-new/
I am interested but will have to get back to you. My clear indicators (different setup to those) have broken on the drivers side where the screw holds it in place and keeps popping out even now and then. Will get back to you
Hi Adam,
Just wondering what the quality of these indicators are like.
Im guessing pretty good seeing the price is more than $200 but ive seen a few around that are made with cheap plastic and the reflective coating on the inside was starting to chip away. How are these in comparison? Are they a particular brand or generic?
Cheers,
Matt
Hi Adam,
Cheers,
Matt
Matt.
To be honest the quality of these indicators is unknown. I have been looking for clear indicators for ages and these are the first and only type I have come accross. I needed a pair for my car and because stock was limited I decided to geat a whole bunch so others wouldnt have the same problem I have had. From the photo I have been given and posted they appear to be alright. The brand is unknown.
Hope that helps.
I still have sort out my money and all but just wondering for interstate buyers what options of payment will you have and would you offer COD?
Once items have landed and on the condition that all of the indicators have not been pre purchased I am happy to send them COD for $250 + Shipping.
I'm also keen for a set, will you accept Paypal for payment?
Sorry mate im not signed up with pay pal. I will only accept cash deposit and EFT.
Hope this helps.
Adam
How can you tell the difference between the GTR and GTS-t indicators? I have a GTS-t with GTR front bar and bonnet, and I'm told that the indicators are GTR ones because GTS-t ones won't fit... Is there any easy way to tell ?? - Thanks!
hey adam did u get my payment??
JEFFERS1987 Thank you very much your payment has been recived. I will contact you as soon as they arive.
What determins your indicators is the headlights and more specificly your front gards. Bumper and bonnet will have no effect. So if you still have the standard gtst gards you will be using gtst indicators.
Hope that helps.
  • 1 month later...
  • 3 weeks later...
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
