On 8th of April i have a Drag event i am taking part in
I was wondering is there any point me stripping out my car and removing my headlight in front of my Pod
Will i get any benefit Stripping the interior or will it be a wast of time
Im hoping to get a 13.99 or better
Yea thats what i was thinking passenger seat out and clear the boot spear tire etc.
at the end of the day im not going down for competition i just want to beat my personal best.
Will removing the headlight and getting cold air to the pod be a good idea or will i just create more drag
yeah 13s is easy with 200rwkw
i got 13.7 @ 105mph with a cold wet track and wheelspin thru first (stupid diff)
to launch generally lower rpm is better, forget trying to launch at 3000rpm, it wont work unless u have a bulletproof setup
try launching at say 1200rpm and clutch slip it progressively
yeah mate, clear the boot out that should be the first thing you do...
Why would you waste your time stripping the boot? the parts in the boot dont weigh bugger all, and in a rwd you want as much weight in the rear of the car anyway to help with traction off the line.
It sounds like you need alot more practice, if you cant get a decent time with that much power and your suspension/tyre setup then your obviously doing something wrong (no offence aaron) , people on this forum have got into the 13's easy with just exhaust mods.
Practice practice practice.
Edited by nizmo_freek
I'm getting 13.7s with all the gear left in and 274/293 rwkw(depends on who's dyno you believe)
tyres down to 20 lb and launch at 4200 rpm. Willowbank sticks like shit to a blanket so it bites pretty damn good and just goes.
Any more revs and i go up in smoke. much less and it bogs down.
Just practice your driving style. Play with your tyre pressures. Draggin is not street running. The little things you do on a strip can all play a part in lowering your et. Gear change is critical, Get it through the gate as quick as you can and experiment with your shift points. I get my best results swapping cogs at 6500 rpm. any more and my times are slower.
A skyline drivetrain can easily handle anything you can dish out at 200 kw's so dont be afraid to give it some. There are cars running with double my horsepower on stock drive trains and hard launches and i havnt seen one break yet. Not to say that it wont happen but hey! you wanna go draggin you have to be prepared to accept the odd failure.
None taken man
I know i need to practice thats y ill be so stoked with myself to pull a 13.99 ha ha
also y i was asking if stripping will make much difference but as most say it will be a wast of time.
Ill just have to try some different launch points and gear change points and hope for the best.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
    • It’s an rb25 so a gtst and I’ll get that valve
    • Thank you for this my turbo doesn’t have the nipple so I’ll get one installed in the turbo to Intercooler piping. I’ll get everything I need and locate it all using the information you both gave and get back with an update.
    • Please do not connect it to your manifold. If you do, as GTS suggested please record the lot in 4K with good mics attached.   On the factory Skyline, there's a upside down pipe that allows it to breathe, looks like this
    • For me I'd need some serious justification for why it has blown out.  Have you questioned him on it?  To be honest if you didn't question him right from the get-go on the first invoice that was already way over the initial quote and then you've (presumably) then paid another $1375 on top of the first invoice, then you're pushing shit uphill to get a favourable result now... It was years ago I last got an engineer out but it was around $450-$550 per visit.  That was just to inspect each progress point he gave me for the project.  Is he just doing progress inspections or is he providing engineering diagrams, technical assistance, etc??  If he's not, he's a filthy rip off merchant.  If the $3100 is the final sign off then you need to cop it on the chin, pay it and move on.  If it's not, piss him off and get a new one.  Not many Jeeps I'd value at $10K full stop let alone just engineering fees on a written off, half actual value WOVR Jeep....
