On 8th of April i have a Drag event i am taking part in
I was wondering is there any point me stripping out my car and removing my headlight in front of my Pod
Will i get any benefit Stripping the interior or will it be a wast of time
Im hoping to get a 13.99 or better
Yea thats what i was thinking passenger seat out and clear the boot spear tire etc.
at the end of the day im not going down for competition i just want to beat my personal best.
Will removing the headlight and getting cold air to the pod be a good idea or will i just create more drag
yeah 13s is easy with 200rwkw
i got 13.7 @ 105mph with a cold wet track and wheelspin thru first (stupid diff)
to launch generally lower rpm is better, forget trying to launch at 3000rpm, it wont work unless u have a bulletproof setup
try launching at say 1200rpm and clutch slip it progressively
yeah mate, clear the boot out that should be the first thing you do...
Why would you waste your time stripping the boot? the parts in the boot dont weigh bugger all, and in a rwd you want as much weight in the rear of the car anyway to help with traction off the line.
It sounds like you need alot more practice, if you cant get a decent time with that much power and your suspension/tyre setup then your obviously doing something wrong (no offence aaron) , people on this forum have got into the 13's easy with just exhaust mods.
Practice practice practice.
Edited by nizmo_freek
I'm getting 13.7s with all the gear left in and 274/293 rwkw(depends on who's dyno you believe)
tyres down to 20 lb and launch at 4200 rpm. Willowbank sticks like shit to a blanket so it bites pretty damn good and just goes.
Any more revs and i go up in smoke. much less and it bogs down.
Just practice your driving style. Play with your tyre pressures. Draggin is not street running. The little things you do on a strip can all play a part in lowering your et. Gear change is critical, Get it through the gate as quick as you can and experiment with your shift points. I get my best results swapping cogs at 6500 rpm. any more and my times are slower.
A skyline drivetrain can easily handle anything you can dish out at 200 kw's so dont be afraid to give it some. There are cars running with double my horsepower on stock drive trains and hard launches and i havnt seen one break yet. Not to say that it wont happen but hey! you wanna go draggin you have to be prepared to accept the odd failure.
None taken man
I know i need to practice thats y ill be so stoked with myself to pull a 13.99 ha ha
also y i was asking if stripping will make much difference but as most say it will be a wast of time.
Ill just have to try some different launch points and gear change points and hope for the best.
    • There's a post from a member (can't recall who), went down the path of a twin scroll G30-660 and it's doing over 300kW+ AND comes on about the same as a high flow RB25DET turbo. Have your cake and eat it too in this case. TBH, if I had a 2nd chance of building my car again (i.e. someone gave me what I wanted for my shit box, but the deal was I had to re-build another R33 and keep the change) I would just pop in a stock NEO motor (with new seals, rod bearings, ARP studs, head gasket, sump, Nitto pump), get a smaller twin scroll turbo, modify the stock low mount (keep the divider in place), and make a solid 300kW on 98RON and call it a day.
    • It's all the sound deadening, and extra shit piled into them, plus all the extra (even though it's thinner) material for crumple zones. I can't fathom in modern cars why they need canbus to the headlights, and why the headlights must be vin coded on some cars to the ECU, BCM, and security module! Especially when they claim it's for security, yet, the canbus at the headlights let's thieves steal the car in minutes, so even more cars are being stolen! The Mercedes Sprinter 907 vans. They're a huge van, but a "basic" van. Yet they have that many canbus networks, plus two Lin networks, AND an Ethernet network. Logging a single network alone of 8 byte data frames, and they will generate a 20mb log file in 5 minutes. That's one network, and I can't remember the exact amount, but there's over 10 full CAN2.0B networks in them. I'm not a fan of modern cars, oddly, more and more I hate DBW, and all the bullshittery the cars try and interfere with. But all that bullshittery adds weight, plus crazy regulations on crumple zones, plus, ever picked a modern seat up, half of them have like 4 electric motors in them and will weigh 30+kg each. Then all the motors for things like adjustable steering columns blah blah blah. And did I mention the sound deadening so you can even hear an ambulance right behind you even if you 7.2surround sound is off?
    • Ah ok, yeah it should be flat, I believe the r34 battery tray has these 3 bumps in them they makes it line up and everything is flat, don't see how it would tilt if everything is secured.
    • Agreed it actively wants to kill you which I love driving fast cars slow is my stick
    • Awesome! I was thinking S14 since they are longer. I'll give those a shot. Thanks for the input!
