I have recently rebuilt my '96 R33 GTS-t, replacing the turbo and many other parts. The following are whats been left over either not required or replaced as explained. Prefer not to ship the turbo or dump pipe if at all possible. I am located in Melbourne.
ARC - Airbox
- As above, suits a ECR33, was used for around a year
- Has ARC label and suits the standard turbo or the GT-RS above. The GT2835 has a different outlet so no longer fits.
- As per Nengun - ARC Airbox
- $250
Defi - Exhaust Temperature Gauge
- Not required, had plenty of other gauges
- The Defi control box is required to operate, but comes with sensor etc.
- This is not a BF but a normal Defi Link - Gauge
- $180
Nismo Low Temp Thermostat
- Not needed, brand new never installed
- As per Nengun - Nismo Thermostat
- $50
SOLD PENDING PAYMENT
Catco - High flow cat
- Highest flowing cat available, brand new, never installed
- As purchased from batmbl on the forums - BOS Importing
- $320
SOLD
CES - Split Front/Dump Pipe
- Purchased from CES in Queensland for around $600 (should be able to find receipt)
- Was purchased as the stainless steel with ceramic coating model
- Attachment has been inserted by mechanic for tuning/etc.
- Splitter flange for the turbo has been removed to suit the GT-RS turbo (which already has this)
- Some scrapes on the bottom, can take more photos if required
- $200
SOLD
HKS GT-RS turbo + short parts
- Was replaced with a HKS GT2835 after rebuild
- Original installation problem damaged core which was replaced by Racepace (receipt available) at a cost of ~ $1000 less than 10,000km ago
- Brand new HKS lines/connectors (from the new GT2835)
- Original HKS J Pipe
- Purchased at Nengun - GT-RS May 2005 for $2600
- $1800 - Will now do $1700 + post
SOLD
Blitz - SBC Dual Solenoid Boost Controller
- Among the best available boost controller with dual solenoid
- Brand new, ended up not needing it
- As available on Nengun - Blitz SBC
- $420
SOLD
Greddy Radiator Breather Tank
- 8mm as available on Nengun - Greddy Breather Tank
- $120
SOLD
Greddy water temp gauge adapter
- not needed, brand new never installed
- As per Nengun - Water adapter
- $20
SOLD
Nismo - Fuel Pressure Regulator
- Not needed, brand new never installed but no longer have box
- As per Nengun - FPR
- $120
SOLD
Greddy - Catchcan
- Used, comes with hoses to fit ECR33 breather lines, no longer needed
- Fairly good condition, genuine Greddy as purchased from Nengun
- $90
SOLD
XTR - Turbo Bag
- Rough condition, should still work fine
- $50
SOLD
Edited by halz
- $120
Greddy - Catchcan
- $90
ill take these two thanks im on the gold coast tried to pm not shore if it has worked
I'm keen on the Defi Exhaust Temp Gauge, assuming it's the DF-02406.
Will check my finances in the next few days and let you know via PM...
Updated some items and yes the gauge model is: DF02406.
- $120
Greddy - Catchcan
- $90
payment sent thanks
Halz, does the turbo come with everything it came with brand new? Would be a straight bolt on no fuss on an RB25 as HKS intended right? Still contains the HKS actuator etc.?
do you know how much the turbos are good for?(power figure)
I was making a solid 240rwkw tuned by Racepace. Originally when it was not installed correctly and the ball bearing catridge had broken. Racepace replaced this no more than 5,000km on the new catridge. It spins freely and has pratically no play in it.
But as it turns out, I had a broken ringland in #6 and ended up having to get a complete engine rebuild where I opted for a larger GT2835 which is making 270rwkw.
Yep, comes with everything that was included as from HKS. The oil water lines from the GT-RS was re-used on my new turbo, so the oil/water lines as the brand new ones from the GT2835 (identical). Also includes the J pipe.
Install should be pretty simple, suits the standard manifold (which I still run) and I had the dump/front pipe as for sale above -- uses the standard exhaust flange.
    • Thanks, plan is to drain all fluid tomorrow and do smoke test to find out the leak.   Appreciate your help and want to understand how the system work. So cooling is achieved by the long loop not any rad? The diagram seems to suggest it connects to somewhere inside the cabin and I thought that is a cooler inside firewall. If you look at the diagram it seems to show it connects to something inside firewall. I tried chasing it but not easy unless I take loads off   i am confident pump is good as fluid goes in and it gets soft( steering) but as soon as I turn engine off , loads of bubble come to surface and overflow. When engine is on , fluid level is below minimum but when off it shoots off and thinking it is sucking air in. I suspect aluminium pipe may have a crack line or whole   smoke test with no fluid should be a good start and if needed will remove the pump   In addition, the one going under the engine bay is high pressure line and one directly connecting from pump to resorvoir is return/ low pressure?   finally I searched and suggestion is to use dexron 2 but that is discontinued so bought dexron 3 as all research suggest it is compatible and shouldn’t cause any issues/ blow seals. I bought two liter of dexron 3 motul atf
    • Don't worry about. Just don't try to drive hard enough to make boost and you'll be fine.
    • Yes. This has already been said. It is a loop of hardline in front of the radiator. Because.... the pump is on the LHS and the steering rack hydraulic connections are where they always are on a RHD steering rack....on the RHS. The high pressure line goes down under the engine, along the crossmember, like it does on all Skylines. Don't just throw expensive braided hoses/other kits at it. Work out what is wrong and fix that.
    • Still got the afm on the intake, clamps are shut tight, only loose hose is the one that goes from the j pipe towards the IACV, since it's next to impossible to find a factory hose and the barbs are different sizes (I'm still using clamps on this hose to try and help it seal on the iacv side) I've ordered parts to make up the hotside of the intercooler pipes, I'll plumb it in and see what happens in a few days I suppose The turbo's internally gated, can I just unscrew the tension rod to let the gate open?
    • Did this ever go further ? Would love some updated info
