im doing my new engine, need to replace studs and gasket.. i know its going to be a bitch as the last engine was a whore.. i will update you all on how many i break and whos balls i break to get them out lol
Just wondering if anyone can give rough prices on these gaskets and studs, more so gaskets, am looking at updating turbos soon and wondering if the HKS kit with all the gaskets & studs included might be worth it If I can get it cheap enough compared to the garretts wher you have to supply your own?
Used drills and reamers to enlarge the stud slots in the manifold (would have been better with die-grinder - but bunnings wasn't open).
What a c..t of a job.
All looks good now - machined manifold sat flush against head. Almost all back together. Will get some new sparkies tomorrow while piping is off.
It appears the manifold was out from the factory. You could see where all the yokes (spacers) had been sitting and there were a few of them right at the extremities of the slot, stopping the manifold from going on. Wonder if the bloke on the assembly line had to have a hammer with him... hahaha
Edited by benl1981
Hey ben
Nah, it's hard to describe, but i'll try my best. try and visualise it. When it was new, it would have gone smoothly on, like how it does now after you enlarged the holes. The studs would haev sat where they were.
The problme is, being cast, that it warps. After machining it, the manifold is still warped. So where the holes used to be isn't where it is now. Machining it just makes it flat, doesn't unwarp it.
I see your point but I doubt the yokes would have moved over time i.e. you can see they are well off centre by the mark they left..
Good point about the warping and then machining. The amount it had warped was only enough to be out by about 0.8mm end to end, hardly enough to make the huge difference at the slotted holes.. but I guess possible.
I just hope the studs dont give way again otherwise Ill be pissed.
Changing turbo + manifold removal etc takes a while. Would be quicker next time - but hopefully there isnt a next time, atleast on this car :sick:
If you torque them correctly, and if the manifold is machined flat, it should be right. The manifold has already warped, so it might not warp much anymore.
Like I said, my car's still got the stock studs in there, and they haven't broken yet (my car has very very low ks though)
Drivebai.
Stud remover bloke: $140 including new studs
Exhaust manifold: $88 Nissan + a couple of missing washers (about $5)
Machining of manifold: $60
So just under $300
I can Pm you the stud remover bloke details. He was pretty good.
Just to confirm, was that $140 including the price of all studs?
How many broken ones needed to be removed?
cos if that's includign the price of all studs, that's not a bad price, coz there's quite a few there, so at $2 each, it's not to bad.
Most stud remover guys charge about 60-80 just to remove 1.
It was to remove 2 broken ones.
He provided the 12 studs and fitted them. Yeah for peace of mind I think it was worth it. He did ask if I had attempted to take the stud out..if so the price goes up to $230+ straight up
That's not bad actually.
that's $24-36 ($2-3 each) worth of studs.
Then a $20 callout fee.
So he charged about $50 to remove each stud. Thumbs up.
Did he use easyouts? or did he weld onto it? From you watching, did it seem like the broken bits of stud were wedged in tight (easyout almost snapping) or were they quite loose?
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
