Hey guys was just randomly searching across other forums and found this on boost.. just wanted to see if anyone would be interested..
*****well since i'm now apparently running this thing on boost aswell i need to talk to people who want to organise both sunny coast meets and nudgee meet. Also any suggestions about final place at noosa too... just pm thanks guys********
SKYLINE CRUISE 2007
That's right it's time for another Skyline Cruise. If I remember correctly the first Nissan Cruise was actually a Skyline Cruise until all the S13, 14, 15 boys started having a whinge
Well boys and girls, polish your GT badges and degrease those beautiful rb's
Date : 20th May 2007
Location - Noosa
1st Meet - Springwood Macca's 9:30am aiming to leave at by 10am to avoid traffic.
2nd Meet - Nudgee Shell time to be confirmed with rohan. (yeah after much inquiries there will me a northside meet, since i'm running it now)
3rd Meet - Ettamonga Pub 12:00
4th Meet - Noosa Hasting Street (depending on parking situation)
***sorry about lack of details but just took it over so tryin to make it work for everyone***
Requirements - Skyline, lots of fuel, cameras, (should see how many chicks we can get to come)
We could simply repeat the first cruise which was personally the best cruise I've ever been on.
Remember guys no stupid stuff we don't wan2 draw any unrequired attention to us...
Attendees:
Redevil
SubzeroR33
Sqd32
Ad_N (Maybe)
Oblivion
Miss_Niz
HR31_RB20DET
Skyline_chick88
The_Enemy
1C3B3RG
Darkness_Ryda1
Hotr34
Kobe_2007
GTR_Chick
R34_VSPEC
Master_bo_bo
J_Boy
GTHR32
70YRB
Scadtional
O.I.C Napster
Wilko_GTR32
MRR34
Yme33
Vinci68
Jason_R33
Edited by redevil
https://www.sau.com.au/forums/topic/162647-skyline-cruise/
  • Replies 181
I've organised kaotic media to come along and film the cruise and take some pics... also thinking about putting some other fottage together and making a dvd
Is there going to be bends? or are you going up the hwy? I know some nice bendy bits on the way.
https://www.sau.com.au/forums/topic/162647-skyline-cruise/#findComment-3038336
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
