Came across the Circuit Club web site the other day and noticed they were having a track day on ANZAC Day coming up. Anyone have any experience with these guys or their events?
http://wp.circuitclub.com.au/?page_id=3
  • Replies 54
I haven't actually been to a circuit car club day yet, but I've heard nothing but good things about them from people on SAU and quite a few of the NSCC guys attend these days aswell. So I figured they must be a good thing!
I believe that they'll also have driving instructors on hand to give tips etc.
I've already booked in for the ANZAC day track day, it's shaping up to be a good one! You should come along!!!!
Liz.
All the trackdays i usually go to are with circuit club, can't be pleased more with there trackdays
-Timing is included (free of charge)
-Cars are split into groups A B C D usually 10-15 cars per group so the track isn't overloaded with cars at one time
-Lockup Garages(Use to be provided at wakefield but ithink this is no longer available since the new owners of wakefield park) - free of charge
They usually have a few guys that can show you the lines and braking points for beginners.
Prizes to the fastest guys of the day
Also their days are usually on weekends or public holidays if you intend on going book 3-4weeks in advanced because by the last 2 weeks they are usually sold out.
If you go with these guys you won't be disappointed, been around for YEARS a very well organised group.
I have been to one of their track days at Wakefield. Well organised event, plenty of track time, official timing included and a pretty friendly group of people. The day I was there, there was a good range of different cars such as Intergras, WRX's, a few Skylines and 200's, even a Ferrari and a kit car.
I would definately go again.
Liz.. last time i went to wakefield after my turbo upgrade..
i ONLY got 2 LAPS per session!!!.. stupid car was overheating.. hitting close to 120degrees after 1 warmup and 2 hard laps..
i NEED A OIL COOLER before i head down :D but i'm so tempted to put the funds towards camshafts for more power ahaha
previously at least i got 3 hard laps with my old turbo which is alright.. so i'm out for the meantime..
I've done a lot of Circuit Club days.
I quite like them. They have instructors on hand (in case you need it, and depending on your insurer you can say its driver training and so probably be covered under insurance), and most of the attendees are sensible. You get the occasional hero (like the idiots driving the Accord Euros at EC earlier this year in the "novice" session that decided to try passing people around the outside of Turn 1) but generally people are well behaved.
I should be at the next EC day.
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
    • I leant out the window recently and took a picture of this new WRX. It looked real damn fine in person. It's faster around a track (stock) than a (stock) GR Yaris. It's much more practical despite being heavier. It's significantly cheaper. This gen tunes really well, much better than others. .... I think they're probably a lot better than people expect.
