It was mentioned before that it's worth getting only if your using slicks because with road tyres you don't generate the forces to cause oil starvation.
It was from another thread, not sure which one though. Ie. I'm too lazy to do the seach... :)
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-333472
yep it's dead easy to baffle ur sum. also there are may other way to do it with filler elements, but yes, ppls say they haven't blown anything up, next time they hear a knock from deep inside, u know that the big end bearings.
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-333632
Hi GTS-t VSPEC, we extend the sump width (not depth as it is already too low). The extensions each hold 1.0 to 1.5 litres of oil when full. This is an old, tried and proven layout, simple and effective
We then put one way doors into the extensions from the sump such that the doors open from the wings inwards. This stops the oil in the sump pushing the door open, only oil in the wings trying ot get inot the sump can push the doors open.
So the doors stay closed when centrifical force is trying to push the oil from the sump into the outside wing. The oil flows from the inside wing into the sump under the same centrifical force. This makes sure that you always have the sump full, thus no oil surge.
This is much harder to explain in words, compared to a drawing, but I hope it makes sense anyway.
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-335440
Originally posted by Sydneykid
Hi Guys, I'm just in the processes of fabricating one for the new RB31DET, I'll post some pictures when it's done.  If you finish yours first, I'd like a look.
Sydneykid, are you going to make a few of these? Or is that just a once off thing?
It sounds like a good idea.
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-337340
Hi ed, we are currently doing 5 X RB31 bottom ends and I think 3 of them are getting winged sumps. So another couple will give the fabricator a bit of a run (I fibbed before, I'm not actually doing the cutting and welding, he is, I just do the design and measure). Cost in mild steel would be around $400'ish if you want to join in, you supply the standard sump. I'll confirm the price in a couple of days if you want something more exact.
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-337371
Hi GTS-t VSPEC, we have ground clearance issues, even without making the sump deeper. Plus you have to extend the pick up which can be tricky and dangerous. Sticking a baffle around the pickup is OK as long as you put one way doors in it as well. But it doesn't increase the capacity of the sump. Which is really an issue in RB engines as at big RPM they carry a lot of oil up high, around the camshafts and valves, not in the sump.
Oil pumps are a bit of a pain. I would like to run a higher flow but standard pressure pump, but they aren't available. They are all higher pressure, some have higher flow as well . Plus the prices make my nose bleed. So I just use the standard R33 GTR pump, with an adaptor ring if it's an RB30 or R32 GTR crank. Never had problem, even with oil coolers and remote filters which put extra load on the pump.
Hope that helps
https://www.sau.com.au/forums/topic/16273-baffled-sumps/#findComment-337537
    • Yeah it was a good result, and confirming the car is full of fluids and all interior etc in, other than fuel. I think a few pages back (maybe many pages!) he mentioned some serious lightening in the doors with the chassis punch, might have been done elsewhere I hadn't seen yet too
    • He still had the suspension dialled in for him! I would have sworn the lowest weight he ever got to was 1300kg though Maybe Neil had been drilling a LOT of holes somewhere you haven't found yet... 😛 Or has he also drained all the gearbox and diff oil out too, between it, and a tank full of fuel there's about 65kg to 70kg to add back in I'd guess. 😛
    • Yeah this isn't a super complex shape, but I was still happy to buy instead of fab version 1; very little in a modern can is a flat surface, and that is true here again - the undertray has about 50mm in height differences that I would have had to work out myself. I will probably make something more substantial before it does any rally, I don't think 1mm steel is too much use as a bash plate. There is also cooling to think about, Z1 have done a bit of development and have some air holes and louvers in the shape, will see how that works out too
    • If it's been tuned idle rpm can be changed.
    • Very slightly as there are bars connecting both sides of the ramp. The only difficulty that I had was doing the gearbox, everything else so far has been ok
