  • Replies 55
Soory guys, won't be able to make it. Had laser eye surgery(highly recommend to anyone wearing glasses) during the week and my eye are still adjusting.
Ah, kick ass!
I was looking at getting this done last month. The $5200 price tag is just a little rich for me at this point.
Have fun today guys!
It was a great drive and everyone seemed to enjoy and behave themselves.
What a way to spend a couple of hours on a sunday; driving along some twisty roads with a bunch of similarly minded people.
We only had one car injury which was a few lost wheel nuts and a sheared stud, meanwhile i got a bit out of shape around a tight corner (owning a GTR doesn't make you a better driver), but other than that it was a incident free event.
It was good to meet up with everyone and see some new faces, we had about 10 cars for the cruise. Hopefully someone can organise another cruise before the SAU track day and we can get even more people to attend.
was a great day out. i coulda' had more fun if my car wasn't f*cked. i was surprised i was keeping up the way i did.... fun was had by most, except for maybe eebl and would definately do it again.
BIG THANKS to Donnan for organising the event which went off without a hitch. well done son... ;)
A sunday drive is really easy to organise, just look at my first post, that is all i did to organise the day!
Maybe someone else could have a crack at it. Just figure out a date, time and a route that is interesting. Try not to change the details much or try to keep them secret as people flake pretty quickly if things change too much or find it difficult to find out what is going on.
Hope to see you all soon!
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
