Trust Intercooler
I would never run E85 without an ethanol content sensor. Just not worth the headache. Having to reflash the tune and only refill the tank when it's very nearly empty is super annoying. -
By DraftySquash · Posted
It’s time to take her out more on weekends!! First thing is a wash. I’ve got my citizenship ceremony this weekend and I’m going to roll up in her 😂😝 Next up will be getting the mechanic to look at my fuel sender O ring around mid-March. I’m saving up for a different front bar so that would be after that. But she’s running happy, so I can sleep easy and slow down. Not chasing power for now. yeah, I’d like to take her down to some meets. but when you’re not on social media anymore, it’s not easy to find those out on time 😂 -
From this comment, I'm assuming you're on the MHD platform. Put it this way, $1k is cheaper than putting a hole through the block. -
Long time no post! Well, I never thought I'd see the day but here we are...
High ethanol concentrations all the time is bad for the fuel system. Not because ethanol has some inherent issue assuming you've done your fuel system setup correctly, but because PIB isn't soluble in ethanol and it contaminates the entire supply of fuel in practice. It is soluble in gasoline so you want to run a tank of normal pump gas every so often to flush all of that out before it causes an injector or something to clog.
