Hey all,
For sale are a set of R33 N1 Turbos for GTR. These are in mint condition, with a minimal amount of side to side shaft play. There is no in/out shaft play at all. When they were removed from the car they were pumped full of oil and coated with some CRC for storage....
These turbos commonly will make up to 300wkw with a good good good tune with supporting mods.
The specs:
A/R 0.42 Compressor
A/R 0.64 Turbine Housing
As far as im aware these are 360 Degree thrust bearing maybe BB? If anyone could shed some light here it would be much appreciated.
Steel wheels both front and rear
Part number:
BB 0201J
14411 - 24U10
466089 - 6C
Asking $1800
1k swap over for good condition stockies, pickup only, in melb. If not in melb price is plus post times 2.
Price outright is 1.4k plus post.
These are FIRM.
GTR stockies MUST be in good working order.
Located in Melbourne, Eastern Suburbs.
Cheers!
Mat.
0400 558 030
SOLD thanks!
https://www.sau.com.au/forums/topic/162774-r33-gtr-n1-turbos-sold/
Hey Mat,
I'm pretty interested in these and have a set (on my car) of stock R32 turbs in perfect nick, I'll also be interested in the bosch 044 you have in your sig and I'll need some 550cc injectors if you have any.
car will be in for a tune at MPC shortly so if somthing can be worked out I can whip the turbos off then
PM me a price if your keen
cheers
  • 4 weeks later...
First post edited.
^^ Note that 1k swap over for good condition stockies is pickup only, in melb. If not in melb price is plus post times 2.
^^ Price outright is 1.4k plus post.
These are FIRM.
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
