Saw ya down at WSID for the drag day last Sunday. I should have come and said G'day but you didnt look like my type mate. Ya boobs arent big enough for me bud. I'd be going back to the doctor who gave you those and getting my money back if I were you.
get over it loser. dont tell me you're having a cry now >_<
poor baby. make sure you do say hi at the next cruise :(
just promise not to check me out again.
get over it loser. dont tell me you're having a cry now :(
poor baby. make sure you do say hi at the next cruise :)
Yeah Boo f*ckin Hoo Boofhead!
I'll say Hi at the next cruise mate no worries.
Hahahaha
Dare you to add it to your next set, Wayne!
I've tried playing on the decks with stuff like that for intros for sets before and also sampling during playing. Nailed a few but not easy to do mate you'll have ta show me! >_<
    • I remembered wrong, but was close though 1Kz setting because those Jaycar SSRs don't go any faster, 1x pump per SSR with flyback diodes & heatsinks. In saying that, the heatsinks are overkill. Just on an alloy plate is more than sufficient. You'll find without a flyback diode, your SSRs will heat up big time and also die prematurely.  I've been running the two same SSRs since the last motor, no issues, car does 2 hour straight drives in summer once in a while and gets punished on the track. Nothing melts, no hot messes, etc.
    • Hmm. You're probably best off working out what the lobe centreline or even the LSA is for the stock cams, with VCT OFF. That's bound to be out there somewhere. Then, work on the assumption that the Kelford centreline is probably the same, and wouldn't be more than a couple of degrees away, if it is different at all. I'm very surprised that you needed to adjust the exhaust cam by 5° to get it on spec. That screams there's another problem somewhere. Anything from the belt being 1 tooth off (how many degrees is one tooth worth?) to simple user/measurement error on the degree wheel. I say this because Kelford, like most quality cam manufacturers these days, does a pretty good job of actually making the cams to spec, not relying on patching it up afterwards like we had to do back in the 80s.
    • Besides packing it, you can also fill your pump through the oil filter inlet port. After cranking for what felt like an eternity without pressure, i fed a tube in through there and filled it with oil. Cranked for a few seconds after that and had pressure.
    • That's exactly what I told myself. I'm happy it came out.
    • My bet is there's a fuse somewhere you blew that feeds power to the ECU. Or you've bumped something out behind the dash board.
