I have read about that the RB engines have a flaw with the oil flow. It's said that the oil stays in the engine head, because of this the bottom end and sump runs dry. Is this because the oil strain seen in the pictures? what would happen if I removed the washer strain or drilled the hole in the middle slightly larger?
Oil pipe between head and bottom end:
With strain washer:
Without:
Should this be here or not?
Edited by h2k
thats the return line on the rb25 due to extra oil in the head from the VCT feed, i wouldnt use that extra washer/restrictor
also not listed in teh workshop manual - see attached
Im not really sure it was there when I disassembled the engine. it's just a washer I had 1 left after I assembled the entire head and it looks like it fits very snug in that oil tube. has the same type of metal as the oil pipe also. But I can't remember if it was there to begin with :\ it's 5-6 months since I took it apart...
I think I'll just remove it.
aftermarket sump doesnt fix the problem....just helps you run around with more oil and hopefully a more reliable pick up.
Definetely doesnt go there, and you probably should have knocked out the back plug and put that down to the sump for an extra drain point.
