HI all, well I have had these ongoing Cold Start issues with My S1.5 R33 GTST.
http://www.skylinesaustralia.com/forums/in...=160180&hl=
http://www.skylinesaustralia.com/forums/in...=157857&hl=
Basically, when I go to start the car when it is below 18 Deg C, the car splatters, sounds like it’s a bit flooded, revs at 300 rpm, then coughs, splatters and is fine from there.
I have done many things, and over the weekend what I did was to turn the fuel pump off, and pressurize the fuel system with air, to remove all fuel, you will be surprised to hear that the car will run for 2 minutes on the fuel in the fuel rail alone.
So after ensuring that there was no fuel in the rail, or injectors, I was hoping to solve my problems of cold start, but figuring out that it’s a leaking fuel injector.
WELL, I reconnected the hoses, primed the lines and the car still started like crap.
So I figure it’s not the injectors, but can someone shed some light on if what I did could prove that it was not the injectors.
ALSO I got Nissan Consult but i can't seam to upload the log file as a txt. All I can see is that the O2 sensor keeps saying rich when starting up cold, which seams weird.
Can someone look over these files and see if there is something REALY obvious that is wrong.
Please help me, I am going out of my head.
ALSO, how much water/moisture, would I need in my engine to cause starting issues?
One this i did notice badly, is that while cranking the voltage drops to below 8 Volts, 7.1 to be exact, i presume this is not good. If somone hads a means of analising the datascan logs, let me know i will send the log to them, i can't seam to upload the .log files.
There is now also a squick in the car, like a vac leak, but it's not a vac leak, and as soon as i touch the throttle it disapears. I have checked for leaks, can't find any, could be a belt or something.
HELP.
https://www.sau.com.au/forums/topic/162820-cold-start-fluffiiee-update/
Have you tried adjusting the IAC's cold start idle. There's a screw on it that allows you to apparently allow more air through when cold.
Mine stops spluttering if I push in more cranking injector time at 10degree's. From memory standard is 24ms, I pushed mine up to 35 and it starts instantly. But thats on a PFC. My stock ecu did the same but obviously not remaped so I wasn't able to test.
Its normal for the o2 sensor to read rich when cold. Since I put the new genuine o2 sensor in it reads 3.98v when I first start the car, then as it warms it quickly drops to 0.2-0.9 and begins cycling.
It can't help doing a vac/leak test. Grab a bit of exhaust pipe, weld a top on to it, 2 t-bolt clamps, either an aircompressor attachment screwed in to the top or drill a hole and use a tyre valve, remove the afm to compressor cover pipe and place the little tool you just made on to the front of the compressors inlet. Spin the motor over to TDC and compress the system to around 10psi. Soapy water and spray it looking for bubbles. :( You can also use a piece of fuel hose shoved in your ear to listen around the IAC and those hard to get to bits (inlet manifold etc)
hay cubes, thanks, that is how i find leaks anyway, will have anothee look see tonight.
I have an SAFC II and a remaped computer, so no go on the cold start enrithcment change, but I THINK i have nailed it down, when cranking my VOLTAGE drops to 7.1 volts, THAT IS BAD i pressume.
I am goign to try another battery to see if that helps.
From some of teh genericl RB25DET logs i have, the lowes cranking voltage i have seen is 9.6V.
So having a shit batery voltage drop is A BAD THING, i presume this can couse a whole lot of problems with igition coil charge times and so froth?
No idea... :S
I had a crapo battery that head a dead cell from new, that was dropping to 9v odd and was sluggish to spin the motor over when cold. But with the correct cranking time at that temp it would still start without a stumble.
  • 1 month later...
  • 3 weeks later...
I reckon on my car, it's the cold start/aac/aircon valve. I have never cleaned them, and i'm gonna give em a go in the holidays. I know you've done all those, but can't hurt to try doing the ones on my car.
Strangely enough, mine hasn't been doing it either, and it's been crazily cold these past few weeks. so strange. I haven't changed anything.
    • Out here E90s are the cheapest way into a sporty-ish car because everyone knows just how expensive the repairs can get. 8-10k USD for an automatic 335i.
    • Noted. Have noticed BMW are more 'high maintenance' for sure. They've attracted my attention as I think the used car prices seem reasonable vs other options, and the extra quality overall vs a commodore / camry / corolla or similar of the same vintage is appealing, especially the interior, and they are more on the sporty side whereas the others mentioned can be more cruising or economical A-to-B only.
    • Haha yeah I know, this is SAU after all, why are we talking about BMW's of all things!? I hear you on the 'don't have to worry about it' side of things. Having been fortunate enough to be have been able to buy a brand new motorbike or two...never really enjoyed them as much as I'd have liked as you worry so much about where you park it, will it get scratched, stolen, attempted theft, knocked over, etc...and yes dirty. Older less valuable bikes you can just go where you want and park it wherever and not really worry that much in comparison. And who cares if it gets dirty! Never owned a V8, and have had my eyes on VE / VF commodores for years but with their prices climbing so high, the M3 has come into focus more as prices are much closer than I've ever seen...is it a potential contender now?...of course need to factor in the S65 'maintenance' especially and like you said general M car 'tax'. One can dream anyway. But more on the reality front - did read the whole 330i thread as well and was a great read too, both threads enlightening as I've never even driven one of these cars! I do recall 330i didn't seem to have the same amount of issues for almost the same car (turbos and related differences notwithstanding)...perhaps down to getting it earlier in it's life so looked after better than the 335i? Perhaps so as your 130i has been good and quite similar, so finding a car that's been looked after well is the especially-crucial-BMW-first-step.
    • Nice. Dont worry about the time of not running. My current skyline hasn't run since I bought it. About 8 years ago.
    • It's also worth noting that I am heavily and unconditionally biased. I've had a lot of cars including some GTRs a fair while ago. I love my BMW's now a lot. They make no sense a lot of the time and the guys on here remind me regularly that I could get something else that does what I want better and cheaper. If you're going to take on an older BMW it's definitely a commitment. If you bail on it early you'll lose money and also the ability for it to put a smile on your face. Stick with it and it just gets better.  f**k I should get into advertising.
