HI all, well I have had these ongoing Cold Start issues with My S1.5 R33 GTST.
http://www.skylinesaustralia.com/forums/in...=160180&hl=
http://www.skylinesaustralia.com/forums/in...=157857&hl=
Basically, when I go to start the car when it is below 18 Deg C, the car splatters, sounds like it’s a bit flooded, revs at 300 rpm, then coughs, splatters and is fine from there.
I have done many things, and over the weekend what I did was to turn the fuel pump off, and pressurize the fuel system with air, to remove all fuel, you will be surprised to hear that the car will run for 2 minutes on the fuel in the fuel rail alone.
So after ensuring that there was no fuel in the rail, or injectors, I was hoping to solve my problems of cold start, but figuring out that it’s a leaking fuel injector.
WELL, I reconnected the hoses, primed the lines and the car still started like crap.
So I figure it’s not the injectors, but can someone shed some light on if what I did could prove that it was not the injectors.
ALSO I got Nissan Consult but i can't seam to upload the log file as a txt. All I can see is that the O2 sensor keeps saying rich when starting up cold, which seams weird.
Can someone look over these files and see if there is something REALY obvious that is wrong.
Please help me, I am going out of my head.
ALSO, how much water/moisture, would I need in my engine to cause starting issues?
One this i did notice badly, is that while cranking the voltage drops to below 8 Volts, 7.1 to be exact, i presume this is not good. If somone hads a means of analising the datascan logs, let me know i will send the log to them, i can't seam to upload the .log files.
There is now also a squick in the car, like a vac leak, but it's not a vac leak, and as soon as i touch the throttle it disapears. I have checked for leaks, can't find any, could be a belt or something.
HELP.
https://www.sau.com.au/forums/topic/162820-cold-start-fluffiiee-update/
Have you tried adjusting the IAC's cold start idle. There's a screw on it that allows you to apparently allow more air through when cold.
Mine stops spluttering if I push in more cranking injector time at 10degree's. From memory standard is 24ms, I pushed mine up to 35 and it starts instantly. But thats on a PFC. My stock ecu did the same but obviously not remaped so I wasn't able to test.
Its normal for the o2 sensor to read rich when cold. Since I put the new genuine o2 sensor in it reads 3.98v when I first start the car, then as it warms it quickly drops to 0.2-0.9 and begins cycling.
It can't help doing a vac/leak test. Grab a bit of exhaust pipe, weld a top on to it, 2 t-bolt clamps, either an aircompressor attachment screwed in to the top or drill a hole and use a tyre valve, remove the afm to compressor cover pipe and place the little tool you just made on to the front of the compressors inlet. Spin the motor over to TDC and compress the system to around 10psi. Soapy water and spray it looking for bubbles. :( You can also use a piece of fuel hose shoved in your ear to listen around the IAC and those hard to get to bits (inlet manifold etc)
hay cubes, thanks, that is how i find leaks anyway, will have anothee look see tonight.
I have an SAFC II and a remaped computer, so no go on the cold start enrithcment change, but I THINK i have nailed it down, when cranking my VOLTAGE drops to 7.1 volts, THAT IS BAD i pressume.
I am goign to try another battery to see if that helps.
From some of teh genericl RB25DET logs i have, the lowes cranking voltage i have seen is 9.6V.
So having a shit batery voltage drop is A BAD THING, i presume this can couse a whole lot of problems with igition coil charge times and so froth?
No idea... :S
I had a crapo battery that head a dead cell from new, that was dropping to 9v odd and was sluggish to spin the motor over when cold. But with the correct cranking time at that temp it would still start without a stumble.
  • 1 month later...
  • 3 weeks later...
I reckon on my car, it's the cold start/aac/aircon valve. I have never cleaned them, and i'm gonna give em a go in the holidays. I know you've done all those, but can't hurt to try doing the ones on my car.
Strangely enough, mine hasn't been doing it either, and it's been crazily cold these past few weeks. so strange. I haven't changed anything.
    • Hey guys, Just want some advice on r34 GTT ac system. Since I’ve owned it, the ac compressor, doesn’t matter the set temperature or ambient temperature, runs for around 10 seconds then disengages the clutch, then re-engages everywhere 30 seconds or so and keeps repeating this.    is this normal?   I had it recharged today as it was slightly low and thought it would fix it but still does it. it cools fine in summer even prior to the recharge, except for the usual warmup when stopped or in traffic (still yet to wire overheat fan to on with ac)   any thoughts would be much appreciated
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
