Hi all
I have a strange whistle/Squeak at idle in my car. It is constant, and as soon as i blimp the throttle it disapears. Only occrs after the car has warmed up. I have all new gaskets and studs exhaust side.
It is hard to see where the noise is coming from, and as you turn the car off, it dies down with the engine.
No recently i cleaned my TB, and Cold start valve, and have since look at these again, but i cant find any issues with these. The engine hasn't lost Vaccuume, and still dirves fine.
Is it possible that it is a whistle from the TB or something similar.
https://www.sau.com.au/forums/topic/162821-whistlingsqueaking-at-idle/
i have the exact same problem = and the same symptoms . the it is really hard to diagnose where it is comming from . sounded like any air leak at 1st, but then it changes tone a bit . my car has been sitting for a few months with out more than a 100 meter drive which iv done like once ever few weeks.....
if i knew where it could be from id be looking for ways to fix , iv just given up.
i have the same squeek at idle goes away while driving..... not sure if its the belts or what.... sounds real dodgy when idleing and gets louder when its hot and been driven for a while.....could it be the cooling fan bearings?
  • 2 months later...
Check all three belt tensions first - make sure they are not loose.
I suspect the sound is coming from the bearings on the air con compressor pully - the one on the compressor - not the tensioner pulley.
I had a noise I couldn't identify - I just got a new water pump fitted so it wasnt the issue.
So I took off the power steering pump belt and the noise was still there.
Then I took of the aircon belt and presto - the noise was gone!!
I rotated the pulley on the air con compressor by hand and it was extremely noisey - you could feel the "roughness" when rotating the pully.
Try it yourself and see.
The CAS noise sounds like a rerw rew rew rew rew.
The air con pulley noise is more like a metal squealing or squeaking - and is constant. Not pulsing like the rerw rerw rerw of the CAS
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
