well as far as ive heard, you got a good set of splits! focals rock my world (but others may differ?)
as for instalation...depends on your experience with splits...if you are a noob, you might want to talk to someone who has done it before. get some tips like tweeter position(but i guess thats why you posted in here:D)
I hate them speakers in the front i was hoping to put something in there wack the factory cover back on and forget about em but what brand make 6x4 or 5x4 or what ever they are...seriously, i found some vdo 90watters that i almost bought but the screw holes didnt line up, so i figured if i was gunna have to dick around trying to fit some shitty speakers in i might aswell save my time and get some good ones. So now i am looking for some competition class splitts......will watch this thread to see if any one has a recipe for installing them.
well i spent sooo frikin long making up the spacers ... in the end i dont' know if it was worth all the hard work i put into making it ... i was lucky i have all the tools at work to make it easily ... but still ... i think if i had known how hard it was originally ... then i would of just bought something that fit my fronts ... its pretty easy to make ... all u gotta do is cut out a peice of mdf that will fit the space of the hole thats in ur door ... accurately mark where u have to screw the spacer onto the door panel so it fits nicely ... then buy some circle spacers that will fit the speakers ... make sure that there is enough room in the back and the front of the speakers ... so that the electric windows dont' get in the way when its winded down ... and that the stock grills dont touch the cone ... even give it a bit of space cause the cone will move out a bit when its given abit ... i'll try and answer anything else ... hope it helps ...
Dudes..i went got the 6.5 inch focal speakers put in my R32 skyline . They Removed the plastic mold inside the door and cut out a piece of MDF to cover the existing mold. Cut out a 6.5" hole and screwed in the speaker. After that the put the door back in place and you cant even tell.
They speakers are fantastic and i recommend them to anyone.
Therefore 6.5" speakers do fit in a R32 SKyline!
Guest Ricky_B
Focal is a excellent brand.
ive got four 6.5" 2 way speakers in my r31 and they pump as far as modifications go they are a pretty deep speaker and i had 2 use doormounts (just a black piece of 6.5" pvc pipe!!)
P.S. is you do use the el cheapo 6.5"pipe door mount you will get alot better sound if you drilled small holes into the pipe if u get wat im sayin
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
