For Sale:
My 97 Nissan 180sx Type X SR20DET
Details:
58,000kms
White with blacktop (top half of the car is black, including roof, side mirrors & 15% tints)
5sp Manual
Vertex rear, sides and custom front bar.
15% all round tints
Tein springs & KYB shocks
17" Black SSW Mesh wheels with chrome lip (brand new tyres)
Momo gear knob
JBL 6x4 front speakers
Xforce turbo back exhaust
Apexi AFC
Greddy Type RS bov
Greddy turbo timer
HKS air filter
Mongoose M60 alarm + window lifts
Description:
The car has never been boosted and engine is basically stock besides very minor bolt ons. Major service was done only 500kms ago (oil, coolant flush, sparks, fuel filter, oil filter and cleaned air filter). Car was near stock when I bought it so all mods were done by me and because I've only clocked 10,000kms on the car, all mods are basically still new.
Rego is all the way till October.
Both the exterior and interior is perfect, exterior has 2 minor dings thats it. I'm very confident its one of the best example of a Type X available on the market.
Reason for sale:
I've found a new job and it involves long distance travelling 700km+ a week so the Type X no longer suits me. It'd be too much of a waste clocking up all these KMs on this car.
Asking price is $18,500ono You can contact me on 0422 085 405
Car is in Sydney, serious buyers only!!!! Pics will be up this weekend after a good clean.
*STRICTLY NO TEST PILOTS*
**I'm not after a swap too**
Thanks
Nelson
https://www.sau.com.au/forums/topic/162832-my-97-nissan-180sx-type-x-sr20det/
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
