He fixed the reverse and is all good 3 years on....but the 4 gear syncro problem reappeared after close to 2 years had passed....and i do NOT flat shift :)
thinking about another rebuild now....:)
Yeah, I'm getting the impression that 4th synchro is piss-weak in this 'box. Seems to be a common complaint. It's making Me think I should've looked harder at a gearbox conversion, but then I really don't want My car off the road for a month while I sort something out - Life sans-wheels SUCKS !
Yeah, thanks abcent - A mate in the trade is seeing in the morning if he can get a changeover from Japanese Gearbox Wholesalers in Rowville, if not I'll probably flip a coin between 360 and Competition - they both sound pretty good, and charge similar rates, and they're practically a stone's throw from each other !
You got an address to this gearbox changeover business in rowville?
Are they open to the public or only to mechanics
Thanks
edit: found
http://www.japanesegearbox.com.au/intro.html
This is like around corner from me! must check it out, thanks for mentioning it :thumbsup:
Thanks
edit: found
NOOO changeover boxes for R33 GTS-T there, and apparently they're not too fond of doing parts - i.e. whole 'box or bust.
Crosses off rb25 gearbox conversion off list.
If they can do a changeover for my rb20 gearbox for cheap i might go ahead with it! ^^,
I've dealt with Stuart (owner) at JGW before, nice guy and he helped me out when dealing with nissan over gearbox issues, but never actually got anything from him so can't comment on what his stuff is like... he seemed to know his stuff, but i think snowy had troubles with his gearbox there...
Well, the bad news is in . . . . .
Nissan have superseded the parts I need (or something), the upshot being that I'd need to buy complete cluster sub-assemblies, which would put the total rebuild bill over $4000.
I shit You not.
P.s. Competition Gearboxes have been great, & both they & 360 Gearboxes can still do a bearings & Synchros rebuild at SURPRISINGLY good prices. I'd suggest anyone with 4th gear selection problems think about a preventative rebuild.
Justjap advertises rb25 boxes for $3200 so i assume you could get them even cheaper shopping around direct from Nissan.
http://justjap.com/parts_ngearbox.htm
Just in the process of cleaning-up the 2nd hand 'box, to install this week/end.
Pics of the old, dismantled box:
5th/Reverse Lockout open:
5th/Reverse Lockout ENGAGED:
H-Pattern the sits below the gearstick . . . . who wants to do a big one inside the cabin - Ferrari Style? ! !
Busted Selector Fork (Notice the worn-smooth bit, where it's jumped-up onto the selsctor Ring when it jammed):
It's even got the rib broken-out:
Hmmmm, What's missing here:
1st/2nd Fork on the left - notice how it's NOT BROKEN ! !
More Brokenness:
I keep on finding bits & Chunks of Aluminium throughout the 'box, not cool. Apparently that's ok though, coz the gear teeth are so hard it just squashes 'em and spits 'em out into the oil ! (hence the T-1000 oil)
WOO HOOOO ! ! ! !
I Went with a cheap 2nd Hand gearbox, which is in, and it feels FINE ! :) Fingers crossed !
Looks like I've got an R33 GTR gearset, and a GTS-T casing + output shaft + spares galore for sale. Make Me an offer !
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
