I read the other threads about this and tried splicing off the parker lights, problem is, the boost gauge stays lit even when the lights are switched to off. I tried all of the wires in that harness, 3 caused it to light up but each time it remains lit when turned off. What do I need to do to fix this?
edit: seems I have mistaken the headlight power for the parker lights, can someone tell me where the parker light circuit is in the r32s? I'm no good with wiring.
Edited by will-32
https://www.sau.com.au/forums/topic/162897-sourcing-power-for-boost-gauge/
Why dont you have it running off the accessories wire from your stereo.
I have all my gauges powered off that. Unless you are mounting your pods on your pillar and have a problem running wires that far, I reckon thats the easiest place to run wires off.
Edited by ProphetR33
yeah I couldnt find any extra wire that was a small enough diameter to run it that far, so I'm trying to connect it to the lights, I just don't know where the correct circuit is.
Goto bunnings, mitre 10, autobarn, supercheap auto or wherever and buy a 10m roll of small gauge electrical wire for $5. :D
the smallest gauge I could find was still a fair bit bigger than that of the gauge (apexi) and the people I asked said it would probably have too much resistance so I didnt buy any of it, do you think it would still work fine?
And yeah I got a multimeter but before I tried to use that to find a good wire, I connected it to the headlight circuit and it lit up so I thought that was the job done, I just didnt get why the gauge light wouldnt turn off when the headlight switch was off..
Cigarette lighter wires.
best thing for guages, has everything you want... and really easy to get to.
12V positive
Negative
12V Lights on wire
Agreed. Cigarette lighter wires are the easiest ones to use.
If you want the guage light to come on with ur stereo use the accessories wire from the stereo.
If you want the guage light to come on with ur ignition then use ur multi meter to find a wire that is 12v when ignition is on and 0 V when ignition is off.
In the same way if you want it to come on with ur parking lights find the wire in the cigarette lighter that is 0V when off and 12V when parker lights are switched on.
I use wire taps to connect up the wires. I find this the easiest way.
awesome, thanks
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
