As above, they use electrospark erode.
But if thats not an option, try welding a nut to the stud stub and then get into it while its still hot. Usually the combo of a nut welded on [good leverage] and the heat loosens thwe stud.
I don't like thread guys with the electro zappy thing. IMO, welding a nut on works everytime.
Some people are good at using easyouts. I haven't had a good experience. They're very brittle. Skilled people can. My theory on it is, the stud/bolt broke for a reason. It is because it's seized in there. So if a spanner on a big nut can't undo it, a skinny little thing in the middle of the stud/bolt won't remove it.
Using a tig to weld a nut on it heats it up too and can help break the bond. If the nut snaps off, we just weld another one on until it comes off.
Ive snapped 5 studs in total now in my rb25, and never once has one of them left a tail poking out of the head.... How do you remove a stud thats IN the head?
Steve
some can use an easyout (I don't know how to use them without snapping them).
I put a washer on it (to protect the head) then get my friend to weld it - build up the weld till it comes up. Then weld it to the washer. Put a nut on the washer ,and keep building up the weld till the nut is filled. Then undo it.
Get the thread guy out as you are stuck now.
Easy outs are a piece of piss to use, it's all about being careful.
1) center punch the snapped stud so you are centered when you drill
2) pilot hole with a small drill and make sure you are as close to square as possible (90 degree adapters help if you are doing it on the car). go right through the stud (about 15mm) new drill bits make life easy here. 10 bucks in drill bits is a small price to pay. If you can drill it without snapping the small drill bit then you can use an easy out.
3) drill it as big as you can without being bigger than the stud obviously, The stud usually loosens and spins in as you drill if you are square as they are not bottomed out
4) use the biggest easyout you can, it means it's less likely to snap
5) do not use a big shifter, use a small 12mm shifter if you don't have space for a proper tee. and support the easyout so you aren't pushing the whole lot off center when trying to turn the thing out. It won't be so tight you cant move it with minimal effort, it will just be the end of the thread is damaged slightly from the shoulder of the stud. That combined with the heat fatigue of the stud is the reason it snapped in the first place.
the studs break because they have been worn out with excessive expansion and contraction with the heat, the material used back then was shit. sometimes they just fall out without doing anything to them. i had a few missing when i took my head off as well as some breaking when i took the manifold off.
for $1.50 each from nissan you can have brand spankers in there.
easy outs work well, i find using a shitload of wd40 helps as well as the biggest possible easy-out bit that will work. the small ones WILL snap and if they get stuck in there you have to either get a diamond drill or do the nut-welding jobbie.
Joe, you good at using easy outs? If I ever need to use em, I'm gonna get you to do it :happy:
I dunno, just never had a good experience with them. If I need to remove someting, it's usually because the bolt has been seized in, and it's sheered the head. So that means it's stuck in really really really really really tight. So tight that wd/penetrene/crc/inox can't even penetrate it.
I figure, if the whole big bolt will snap, the thin easyout has no chance.
Oh! I just read what you wrote BHDave. In that case, I reckon the easyout would be alright. I meant they snap when the bolt is seized in big time.
My friend helped me to remove a bolt using the welding method. The bolt was totally dry when it was removed. The part had been soaked in a bucket of wd for days. That's how seized it was
I just replaced all my exhaust manifold studs today.
Had 6 snapped studs.. I just used a easy out tool. Ended up using a smaller drill bit that came with the packet and grinded the easy out tool down a bit so i didn't have to drill in so much.
Took about 5 hours but only used 1 easy out tool and snapped 1 drill bit.
i ended up getting the last 1 out.. i usually can get them out fairly easily but this one was stuck in good!! welding the nut on the end worked very well.. it failed 3 times but the 4th time i got it.. welding the nut on the end works very well if you have the tools available to you.
I have just been through this with 5 snapped studs they were all snaped off flush with the head I decided to get threadtech out to pull them and remove the un broken ones took about an hour and $110 well worth the money now just to get a new gasket and set of studs
  • 1 year later...
Hey dude
ive gotta get 2 snapped studs outta the head, where did you get your easy outs from man ? were they decent quality ? and what kind of drill bit
cause i know the cheap ones tend 2 break...
Cheers Trav
It was some time ago.. I picked up the ezy out from a hardware store. Was pretty cheap from what i remember.
It comes with everything you need but to make the job easier i just used a smaller drill bit that i found laying around and then if u grind the tool down alittle you wont have to drill so far in, as the start of the tool doesn't really do anything. I also bought a 90deg attachement for the drill (bout 20 bucks) so I could actually get the drill inside the engine bay.
    • Oh yeah forgot to also mention need to also unplug the IACV as well. Thanks for the reminder @MBS206 Unplugging the TPS takes it out of closed loop so you're able to screw down the IACV without the ECU trying to add/subtract timing to maintain the idle (not sure PowerFC can even do this, but Nistune and the OEM definitely does)
    • For sale is my 1999 Nissan Skyline R34 GT-T, tuned to 234 kW / 313 hp. I've had the car for a few years as my daily driver. The car is original (as far as Skylines go), with only a few minor upgrades to enhance performance and driving experience, as typical for such a car of its age. Overall, it is in great condition with no body rust, thanks to its earlier import date. It features a top-notch security system (not literally, but it's great!) with remote start and still functional 4-wheel steering via HICAS. It comes with several performance and handling upgrades, including:     Hypergear 450HP Turbocharger running 17 PSI boost, installed mid-2021 by Jaustech     550cc injectors     Nistune ECU     Front-Mount Return-Flow Intercooler     X-Force Stainless Steel Exhaust     Upgraded engine mounts     Bottom end bearings replaced     BC Coilovers     Lenso DR1 rims     Bridgestone Potenza Adrenalin RE003 TL 245/40R18 97W tires, fitted early 2023 The interior is mostly stock, with a few additions:     Viper Satellite Tracking System with remote start     Bluetooth Double-Din Touchscreen Head Unit     Steering wheel cover Cons:     A few paint imperfections here and there     Driver’s seat shows more wear than the others. It's not torn at all, but I've added a seat cover to protect its condition. I also have a CarVX Vehicle History report available for serious buyers, so you don’t need to purchase it yourself. Price: $26,000 ONO.
    • I've had two suzukis in the past have an extremely hard time turning over and not starting after sitting for a few weeks. Ended up the alternator would seize up causing the starter to force. Same issue both times.  Maybe they're sourcing their alternators from the same place...
    • Ah right. Maybe my rb just loves chewing through batteries lol.
    • On the R34 can't you just unplug the IACV? This is the way I've always done it on the R33. Disconnect IACV, get it idling around 650rpm, and then do a power reset on the ECU to get it to relearn idle (factory ECU).   The big reason no one has touched on as to why you'd want to get the base idle right, is that it means the computer needs to make smaller adjustments to get a good idle at 700-750rpm.   Also, cleaning the IACV won't normally make the car suddenly idle lower or higher. The main issue with the IACV gumming up is that the valve sticks. This means the inputs the ECU gives, aren't translating to changes in air flow. This can cause idle choppy ness as the ECU is now needing to give a lot of input to get movement, but then it moves too far, and then has to do the same in reverse, and it can mean the ECU can't catch stalls quickly either.
