why couldnt you use rb26 bearings?
25, 26 and 30 are all the same size.
For people in the know, it can be common to use them yes.
On a side note...Flyfink that looks like a photo of our first rb30det in your avatar...wtf? That workshop background looks like the shed at home. How the hell did you make that your avatar?
Edited by r33_racer
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3025030
  • 6 months later...
im deciding what brand of bearings to use for my rb25/30. I was thinking of acl but the workshop recommend the nismo which cost around $800. I dont mind paying the extra $$$ but if the acl are on par then no point. Using t04z with all supporting gear and aiming for 500rwkw.
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3438747
My mechanic had bad experiences with King bearings when he had the motor in his car. So when we put it in my car we used NDC bearings. Only done 1000km but I'm getting pressure bleed off at idle.. going to put an N1 pump in next weekend (should have done it before but couldn't source one in time) and see if that helps.
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3439209
Use the ACL race series bearings designed for the RB30. RB26 conrod bearings are different to the RB30 size. You can use RB26 mains in an RB30 but for no real benefit because there is no groove behind the bearings to feed oil to the extra oil holes.
Dont pay big money for Nismo bearings. ACL is about to or is already supplying them with their bearings. The ACL's are the best bearing you can buy in my opinion and very reasonably priced. I think they will be offering them in the future with the Calico coating which would be worth giving a go.
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3439262
If he has now had issues with 2 different brands of bearings I'd suggest the problem lies with himself. :S
I've ran kingbrearings in my own car and a mates; both are still running 3 years later. I've clocked 70,000km's.
R33_racer also runs them and being a race car no doubt see's a LOT more stress; if he uses them and a lot of the VL boys use them then its good enough for myself.
The bloke who built my motor had recently finished a 700hp RB30ET of which also used king bearings and was starting the build up of a 500awkw RB26. I was recommended to spend that little bit more on them as they are an excellent bearing. They haven't let me down yet. :(
But regardless; almost all the good named bearings are decent. Most often than not the problem boils down to the person doing the work. :)
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3439303
Do find out what was apparently wrong with the King bearings as they are used by many others with awesome results.
My guess still comes down to how it was setup/assembled.
Proengines... Have you heard of any issues with the king bearings? I'd assume you would have caught wind if there was. :O
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3440201
No real issues as such. I have seen some that have started to flake, as in the bearing material has separated from the backing but only due to severe detonation. I use ACL race series in everything that they are available for now, I've seen a set of rod bearings out of Sainty's top fuel engine which still looked like new after quite a few runs. I also have a set here from an ej25 I did that made well over 500rwkw and they are the same, look as though they just came out of the box. The ACL's seem to cop a lot more before they start to have problems.
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3451562
you can use rb26 mains....as i said previously, you groove the block to suit and then you can take advantage of the extra oil feeds per bearing.
we have used kings in two race motors so far...both with no problems. 1 racing mile = 1000 road miles. That should give a rough idea of how much extra wear and tear goes into a race motor as opposed to a street car. In one event during a day you would do equivalent to roughly 15,000miles of wear.
https://www.sau.com.au/forums/topic/162939-rb30-bearings/#findComment-3451994
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
