R33 Bonnet Bulge
Is this preventable by priming the system with external oil pressure? I've seen the speed academy folks hook up an external oil priming system to the oil pressure sensor port with an air compressor to check for oil leaks before putting an engine back in a car. Something like this: https://www.jegs.com/i/JEGS/555/23550/10002/-1?gPromoCode=SPRINGINTOSPEED_APR25_5Off&gQT=1 -
Do the R32s run high or low impedance injectors?
It may not feel like it to your wallet....but sounds like this was one of those "lucky you did it" rebuilds. Hopefully you have better luck this time
It's aftermarket. It also reeks of Honda Civic tryhard from 2003. But if you want one....then you want one.
